Help! on nested replicant issue
shyamreb
I'm trying to access items in a nested loop using the <replicant> tag in the datacapture.cfg file, and the <iw_iterate> tag in the style.tpl file. There are two levels of replicants -- I'm able to access first-level items, but unable to access the items at the second level.
Here's the code from my datacapture.cfg file:
<!-- Style information -->
<item name="Style Collection">
<label>Custom style data collection</label>
<replicant min="1" max="100" default="1">
<item name="Style HTML Tag Override Indicator">
<label>Style HTML tag override (Y/N):</label>
<description>Determine if the style is an HTML override style</description>
<radio required="t">
<option value="Y" label="Yes"/>
<option value="N" label="No" selected="t"/>
</radio>
</item>
<item name="Style Name">
<label>Style name:</label>
<description>Custom style name</description>
<text required="t" size="70" maxlength="105"/>
</item>
<item name="Style Attribute Collection">
<label>Custom style attribute data collection</label>
<replicant min="1" max="50" default="1">
<item name="Style Attribute Name">
<label>Style attribute name:</label>
<description>Custom style attribute name</description>
</item>
<item name="Style Attribute Value">
<label>Style attribute value:</label>
<description>Custom style attribute value</description>
</item>
</replicant>
</item>
</replicant>
</item>
Here's the code from my style.tpl file:
<!-- Loop through style collection to get custom styles -->
<iw_iterate var='$CustomStyle' list='dcr.Style Collection' iteration='$CustomStyleCounter'>
<iw_perl>
<![CDATA[
# Initialize variables
$StyleHTMLTagOverrideIndicator = iwpt_dcr_value('$CustomStyle.Style HTML Tag Override Indicator');
$StyleName = iwpt_dcr_value('$CustomStyle.Style Name');
# Remove spaces from style name
$StyleName =~ s/ //g;
# Begin style entry
if ($StyleHTMLTagOverrideIndicator == "N") {
print CommonStyleFile "." . $SiteID . $StyleName . "\n{\n";
else {
print CommonStyleFile $StyleName . "\n{\n";
</iw_perl>
<iw_iterate var='$CustomStyleAttribute' list='$CustomStyle.Style Attribute Collection' iteration='$CustomStyleAttributeCounter'>
<iw_perl>
<![CDATA[
$StyleAttributeName = iwpt_dcr_value('$CustomStyleAttribute.Style Attribute Name');
$StyleAttributeValue = iwpt_dcr_value('$CustomStyleAttribute.Style Attribute Value');
# Remove spaces and colon characters from style attribute name
$StyleAttributeName =~ s/ //g;
$StyleAttributeName =~ s/://g;
# Continue style entry
print CommonStyleFile "\t" . $StyleAttributeName . ": " . $StyleAttributeValue . "\n";
</iw_perl>
</iw_iterate>
<iw_perl>
<![CDATA[
# Complete style entry
print CommonStyleFile "}\n";
</iw_perl>
</iw_iterate>
Dwayne
I don't generally use the
on my
<iw_iterate>
variables. I'd change your tpl around like this:
Current project: TS 5.5.2/6.1 W2K
shyamreb
Dwayne,
Thank you so much!!! Removing the "$" from the list variable name worked!!!
---Shyam.
Adam Stoller
A couple of nits - not confined to this one posting - but as I see it come up many times I figured I'd throw it here:
When designing your DCTs - use simplfied names for the items and use labels for the descriptive names you want to show in the form. For example, instead of:
</item>
try:
<item name="html_override">
<label>Style HTML Tag Override Indicator</label>
</item>
Then your PT code is a lot easier to write (IMO), manipulate with things like XSLT, and easier to fit within 80-character columns (which then makes it much easier to read if you ever print it out):
my $html_override = iwpt_dcr_value('CustomStyle.html_override');
Food for thought anyway.
--fish
http://www.quotient-inc.com
