Custom Perl Module Help in 6.1
AmyRush
I have just installed a fresh w2k, ts 6.1 and I'm trying to use an old custom .pm. I can't figure out how to use it in this new version. You are so quick, I need a little help, and you'll be quicker than my research, I'd wager.
In 5.5.2 script I had:
use Teamsite::taskhist;
taskhist.pm lives in iw-home\iw-perl\site\5.00503\lib\TeamSite
Where does the new pm have to go and what do I use in my script to execute it?
Obviously, I've forgotten a bunch while my 5.5.2 box was running happily.
Thanks!
Sunil Mugalavally
hi,
You could move the "taskhist.pm" to "iw-home\iw-perl\site\lib\Teamsite\" and the scripts should just work fine with no changes made.
There are a few posts on devnet you could search on if you need more info.
AmyRush
SPECTACULAR!! Thank you!!!
Dwayne
The information provided is correct, and I understand that you're porting legacy code, but ...
IMO, you really shouldn't be using
TeamSite::
as your module package prefix. That makes it look like something supplied by Interwoven, which will no doub confuse the next person who has to maintain the system after you. I would recommend using
MyCompany
(where
MyCompany
is replaced with something meaningful for your company, of course) instead of
TeamSite::
Current project: TS 5.5.2/6.1 W2K
AmyRush
Great point! Thanks!
