Error running MT : Index is not created
psr
Solaris 8
TS 552
MT 351
Getting following error while running menu option on newly created file,
"File", "Run Metatagger", "mtmetaproxy.cgi"
ERROR: Suggest fails. Reason: [SERVER] While suggesting category 'kk_units', the following error occurred. Index 'kk_units_greedy' is not created for this version of the software.
I get the error on newly created files only. It works alright with the old files on which metadata is already set
The error displayed is :
mtserver_9095.log :
2 1112120346: Non-threaded version
2 1112120346: Attempting to load config '/opt/iw-home/metatagger/conf/mtserver_9095.dat'.
3 1112120346: Metatagger Server Started. Version: Interwoven MetaTagger 3.5.1 BN:31802
2 1112120346: Server Started
1 1112120346: [MetataggerServer.cpp,2139] Preload thread failed, reason: While suggesting category 'kk_units', the following error occurred. Index 'kk_units_greedy' is not created for this version of the software.
2 1112120349: Command: save_config
2 1112120350: Command: save_config
2 1112120355: Command: save_config
2 1112120401: Command: validate
2 1112120401: Command: get_full_config
2 1112120405: Command: validate
2 1112120405: Command: begin_file_transfer
2 1112120406: Command: cont_file_transfer
2 1112120406: Command: remote_suggest
3 1112120406: DFceMetadataAdaptor: No driver loaded.
2 1112121239: Command: validate
2 1112121239: Command: get_full_config
2 1112121243: Command: validate
2 1112121243: Command: begin_file_transfer
2 1112121243: Command: cont_file_transfer
2 1112121243: Command: remote_suggest
3 1112121243: DFceMetadataAdaptor: No driver loaded
Servletd.log :
java.lang.Exception: Suggest fails. Reason: [SERVER] While suggesting category 'kk_units', the following error occurred. Index 'kk_units_greedy' is not created for this version of the software.
at com.interwoven.icm.metatagger.Metatagger.suggestCategory(Metatagger.java:497)
at com.interwoven.icm.metatagger.Metatagger.suggestCategory(Metatagger.java:512)
at com.interwoven.icm.metatagger.Metatagger.suggest(Metatagger.java:444)
at com.interwoven.icm.datacapture.BackendAdaptor.getFullSuggestion(BackendAdaptor.java:176)
at com.interwoven.icm.datacapture.BackendAdaptor.getContainerList(BackendAdaptor.java:264)
at com.interwoven.icm.datacapture.FileProperties.getStoredValues(FileProperties.java:71)
at jsp.EditGateway._jspService(EditGateway.java:1504)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:119)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.apache.tomcat.core.ServletWrapper.doService(ServletWrapper.java:405)
at org.apache.tomcat.core.Handler.service(Handler.java:287)
at org.apache.tomcat.core.ServletWrapper.service(ServletWrapper.java:372)
at org.apache.tomcat.core.ContextManager.internalService(ContextManager.java:797)
at org.apache.tomcat.core.ContextManager.service(ContextManager.java:743)
at org.apache.tomcat.service.http.HttpConnectionHandler.processConnection(HttpConnectionHandler.java:213)
at org.apache.tomcat.service.TcpWorkerThread.runIt(PoolTcpEndpoint.java:423)
at org.apache.tomcat.util.ThreadPool$ControlRunnable.run(ThreadPool.java:501)
at java.lang.Thread.run(Thread.java:484)
Any ideas what is wrong?
!Thanks
nipper
Does this happen for all type of files or just specific types ?
Try doc, html. DCR, pdf, etc
psr
Happening to all type of files.
nipper
has metatagger.cfg been changed lately ?
psr
Not really. The last change was almost month back.
