I receive the following exception in the log and couldn't figure out what may be causing it. I can connect to the database using
"jdbc
racle:thin:teamsite/password@****.****.****.xx:1521:abcdefg" connection sting from java program and make changes.
Thanks a lot for the help.
Versions are
OD 6.0.1
Oracle 10g
DD
etting up TDbSchemaAgent.
DD
>> Loading drivers <<<
DD:url : jdbc
racle:thin:
DD:login : teamsite
DD:login timeout=400
DD:Connecting to the database...
DD:Try connecting using jdbc
racle:thin:
@****.****.****.xx:1521:abcdefg...
DD:Connect attempt Failed:Reason:7
java.lang.ArrayIndexOutOfBoundsException: 7
at oracle.security.o3logon.C0.r(C0)
at oracle.security.o3logon.C0.l(C0)
at oracle.security.o3logon.C1.c(C1)
at oracle.security.o3logon.O3LoginClientHelper.getEPasswd(O3LoginClientHelper)
at oracle.jdbc.ttc7.O3log.<init>(O3log.java:289)
at oracle.jdbc.ttc7.TTC7Protocol.logon(TTC7Protocol.java:251)
at oracle.jdbc.driver.OracleConnection.<init>(OracleConnection.java:246)
at oracle.jdbc.driver.OracleDriver.getConnectionInstance(OracleDriver.java:365)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:260)
at java.sql.DriverManager.getConnection(DriverManager.java:512)
at java.sql.DriverManager.getConnection(DriverManager.java:140)
at com.interwoven.dd100.dd.JdbcCheckup.MakeConnection(JdbcCheckup.java:400)
at com.interwoven.dd100.dd.JdbcCheckup.TryConnect(JdbcCheckup.java:539)
at com.interwoven.dd100.dd.TDbConnectionManager.GetConnection(TDbConnectionManager.java:78)
at com.interwoven.dd100.dd.TDbAgent.EstablishConnection(TDbAgent.java:548)
at com.interwoven.dd100.dd.TDbAgent.<init>(TDbAgent.java:271)
at com.interwoven.dd100.dd.TDbSchemaAgent.<init>(TDbSchemaAgent.java:63)
at com.interwoven.dd100.dd.TConsumerManager.getDbAgentBasedOnGroupUpdate(TConsumerManager.java:513)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumer(TConsumerManager.java:586)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumersForOneDeployment(TConsumerManager.java:191)
at com.interwoven.dd100.dd.TConsumerManager.SetupConsumers(TConsumerManager.java:133)
at com.interwoven.dd100.dd.TAgentClient.Go(TAgentClient.java:97)
at com.interwoven.dd100.dd.IWDataDeploy.Go(IWDataDeploy.java:512)
at com.interwoven.dd100.dd.IWDataDeploy.run(IWDataDeploy.java:534)
DD:Attempt to connect using jdbc
racle:thin:
@****.****.****.****:1521:abcdefg failed.
