TeamSite 6.5 SP1 installation problem
System
I installed TeamSite 6.5 with SP1 on a brand new Solaris server. The installation is very smooth, howerver I couldn't view any files in Teamsite.
I am getting the following error message when I clicked any files in content work area. Please advice.
Proxy Error
The proxy server could not handle the request GET /iw/cci/meta/injection/iw-mount/default/main/homepage/WORKAREA/content/img/homepage/features/_car/carn01_ben2_378x195.jpg.
Reason: Host not found
Apache/1.3.31 Server at jupiter.homebox.com Port 80
Thanks
Jason
nipper
Your proxy was not found.
Check iw.cfg for your proxy settings.
Also check your web server settings, TS
usually takes port 80 away from Apache and *should* make it port 81.
If Apache is still trying to run on 80, that is a problem.
go to
http://server:81/
and see if it is running there.
Migrateduser
There was typo with my iwproxy section in iw.cfg file. It's working fine after I fixed the typo.
Jason
