Hi there,
In my docbase I have a lifecycle (dm_policy) installed. In that dm_policy I want to add more object types, so that this lifecycle can be associated with new objects.
For doing this I have imported the existing documentum lifecycle into my Documentum Composer project and added the required types. After that I generated the DAR file and installed the same into the same docbase. During DAR creation I selected the existing object override installation option.
After installation of the DAR file I am able to see two instances of the same lifecycle, instead of a single modified lifecycle.
Are we doing in mistake? Is there any otherway that we should be using for modifying an existing lifecycle? We are facing this problem for the last few weeks and we are stuck on this. Any kind of help regarding this will be appreciated.
Thanks in advance for your help and time.
Raj Kumar
