I'm a newbye.
I have download 2 Gb zip Developer_Edition_6.6_windows_sql
I have tried to install documentum but I have got a infinity number of problem.
I have got a Vista Business OS.
For example now I got this problem:
anyone know how solve?
I also tried to launch manually the batch file and all scripts failed. I don't understand why.
(25-ago-2010 10.58.26), Setup.product.install, com.documentum.install.shared.common.error.DiException, err, An exception occured in: DiWAOemExecuteConfigurationScripts, beanID: executeConfigurationScripts - DiWAOemExecuteConfigurationScripts failed! - 'Creating connection broker and repository ' failed.; Runtime execution failed with child process "C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\launchServerConfigurationProgram.bat -passwords databaseAdmin=<hidden> docbaseOwner=<hidden> windowsInstallOwner=<hidden> globalRegistryUser=<hidden> -config C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\config_docbase.ini -record C:\Users\Lavoro\AppData\Local\Temp\serverRecorded5825037852486767186.ini -silent " exit code of 1; For more detailed information, see the error log: C:\sviluppo\Developer_Edition_6.6_windows_sql\setupError.log
(25-ago-2010 10.58.26), Setup.product.install, com.documentum.install.shared.common.error.DiException, err, com.documentum.install.shared.common.error.DiException: Runtime execution failed with child process "C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\launchServerConfigurationProgram.bat -passwords databaseAdmin=<hidden> docbaseOwner=<hidden> windowsInstallOwner=<hidden> globalRegistryUser=<hidden> -config C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\config_docbase.ini -record C:\Users\Lavoro\AppData\Local\Temp\serverRecorded5825037852486767186.ini -silent " exit code of 1
at com.documentum.install.shared.common.services.DiUtilExecuteCommand.executeCommand(DiUtilExecuteCommand.java:110)
at com.documentum.install.shared.common.services.DiUtilExecuteCommand.executeCommand(DiUtilExecuteCommand.java:50)
at com.documentum.install.shared.common.services.DiUtilExecuteCommand.executeCommand(DiUtilExecuteCommand.java:44)
at com.documentum.install.oem.common.services.DiActionExecuteCommands.install(DiActionExecuteCommands.java:90)
at com.documentum.install.shared.common.services.actions.DiActions.install(DiActions.java:152)
at com.documentum.install.oem.common.beans.wizard.action.DiWAOemExecuteConfigurationScripts.execute(DiWAOemExecuteConfigurationScripts.java:61)
at com.installshield.wizard.RunnableWizardBeanContext.run(Unknown Source)
err: ---- BEGIN "Global Context: " output ---- (Wed Aug 25 10:58:26 CEST 2010)
Wed Aug 25 10:58:26 CEST 2010: [COMMON]
Wed Aug 25 10:58:26 CEST 2010: UI_MODE=AWT
Wed Aug 25 10:58:26 CEST 2010: IS_SUITE_INSTALLATION=TRUE
Wed Aug 25 10:58:26 CEST 2010: BOF_GLOBAL_REGISTRY_DFC_PANEL_IS_ENABLED=FALSE
Wed Aug 25 10:58:26 CEST 2010: ECI_SERVICES_ASK=FALSE
Wed Aug 25 10:58:26 CEST 2010: PIA_OPTION_HIDE=FALSE
Wed Aug 25 10:58:26 CEST 2010: SUITE_MAIN_PRODUCT=serverOEM
Wed Aug 25 10:58:26 CEST 2010: WINDOWS_DIRECTORY=C:\Windows
Wed Aug 25 10:58:26 CEST 2010: WINDOWS_ROOT_DIRECTORY=C:
Wed Aug 25 10:58:26 CEST 2010: DEFAULT_BROWSER=chrome
Wed Aug 25 10:58:26 CEST 2010: VERSION_IEXPLORER=8.0.6001.18943
Wed Aug 25 10:58:26 CEST 2010: VERSION_NAVIGATOR=
Wed Aug 25 10:58:26 CEST 2010: COMPUTER_NAME=PC-LUCA
Wed Aug 25 10:58:26 CEST 2010: USER_ACCOUNT=Lavoro
Wed Aug 25 10:58:26 CEST 2010: USER_DOMAIN=PC-Luca
Wed Aug 25 10:58:26 CEST 2010: USER_IS_ADMIN=TRUE
Wed Aug 25 10:58:26 CEST 2010: OPERATING_SYSTEM=0
Wed Aug 25 10:58:26 CEST 2010: SERVICE_PACK=1
Wed Aug 25 10:58:26 CEST 2010: SCREEN_RES_X=1440
Wed Aug 25 10:58:26 CEST 2010: SCREEN_RES_Y=900
Wed Aug 25 10:58:26 CEST 2010: USER_PROGRAMS_FOLDER=
Wed Aug 25 10:58:26 CEST 2010: USER_GROUP=
Wed Aug 25 10:58:26 CEST 2010: TEMP_DIR=C:\Users\Lavoro\AppData\Local\Temp
Wed Aug 25 10:58:26 CEST 2010: SUPPRESS=TRUE
Wed Aug 25 10:58:26 CEST 2010: EXTERNAL_RESOURCE_PATH=C:\sviluppo\Developer_Edition_6.6_windows_sql
Wed Aug 25 10:58:26 CEST 2010: DCTM_PROGRAM_DIR=C:\sviluppo\Documentum
Wed Aug 25 10:58:26 CEST 2010: DCTM_USER_DIR=C:\sviluppo\DocumentumData
Wed Aug 25 10:58:26 CEST 2010: JMX_USER=acsAdmin
Wed Aug 25 10:58:26 CEST 2010: SECURE.JMX_PASSWORD=******
Wed Aug 25 10:58:26 CEST 2010: DCTM_ENV_SCRIPT_NAME=C:\sviluppo\Documentum\Shared\set_dctm_env.sh
Wed Aug 25 10:58:26 CEST 2010: DFC_FOLDER=C:\sviluppo\Documentum\shared
Wed Aug 25 10:58:26 CEST 2010: HELP_FOLDER=C:\sviluppo\Documentum\help
Wed Aug 25 10:58:26 CEST 2010: CONFIG_FOLDER=C:\sviluppo\DocumentumData\config
Wed Aug 25 10:58:26 CEST 2010: DCTM_LOCATION=C:\sviluppo\Documentum
Wed Aug 25 10:58:26 CEST 2010: SETUP_FILES_FOLDER=C:\sviluppo\Documentum\setup
Wed Aug 25 10:58:26 CEST 2010: GROUP_NAME=MethodServer
Wed Aug 25 10:58:26 CEST 2010: JMX_ENCRYPTED_PASSWORD=BZ/bNimzbfg=
Wed Aug 25 10:58:26 CEST 2010: BUNDLED_JAVA_HOME=C:\sviluppo\Documentum\java\1.6.0_17
Wed Aug 25 10:58:26 CEST 2010: JARS_TO_REGISTER_IN_DCTM_JAR=Shared/dfc.jar Shared/jsafeFIPS.jar Shared/certjFIPS.jar Shared/log4j.jar Shared/All-MB.jar Shared/bpmutil.jar Shared/ci.jar Shared/subscription.jar Shared/workflow.jar Shared/xforms.jar Shared/dam_services.jar Shared/tar.jar Shared/xtrim-api.jar Shared/messageService.jar Shared/messageArchive.jar Shared/xtrim-server.jar Shared/DmcRecords.jar Shared/configservice-api.jar Shared/configservice-impl.jar shared\workflow.jar shared\collaboration.jar
Wed Aug 25 10:58:26 CEST 2010: SUITE_INSTALL_ACTION_COMPLETED=TRUE
Wed Aug 25 10:58:26 CEST 2010: [JRE_ENVIRONMENT]
Wed Aug 25 10:58:26 CEST 2010: java.version=1.6.0_17
Wed Aug 25 10:58:26 CEST 2010: java.vendor=Sun Microsystems Inc.
Wed Aug 25 10:58:27 CEST 2010: java.home=C:\Users\Lavoro\AppData\Local\Temp\LRE3AAF.tmp\jre
Wed Aug 25 10:58:27 CEST 2010: java.vm.version=14.3-b01
Wed Aug 25 10:58:27 CEST 2010: java.vm.vendor=Sun Microsystems Inc.
Wed Aug 25 10:58:27 CEST 2010: java.vm.name=Java HotSpot(TM) Client VM
Wed Aug 25 10:58:27 CEST 2010: java.class.path=;oemWinSuiteSetup.jar;serverWinSetup.jar;indexAgentWinSetup.jar;tcfSetup.jar;dbSetup.jar;dctmAppServerSetup.jar;serviceWrapperSetup.jar;dfcWinSetup.jar;bofworkflowSetup.jar;bofcollaborationSetup.jar;appServer.jar;dbserver.jar;serviceWrapperManager.jar;documentumSetup.jar;C:\Users\Lavoro\AppData\Local\Temp\LRE9EBF.tmp\installConfig.jar;
Wed Aug 25 10:58:27 CEST 2010: java.ext.dirs=C:\Users\Lavoro\AppData\Local\Temp\LRE3AAF.tmp\jre\lib\ext;C:\Windows\Sun\Java\lib\ext
Wed Aug 25 10:58:27 CEST 2010: os.name=Windows Vista
Wed Aug 25 10:58:27 CEST 2010: os.arch=x86
Wed Aug 25 10:58:27 CEST 2010: os.version=6.0
Wed Aug 25 10:58:27 CEST 2010: user.name=Lavoro
Wed Aug 25 10:58:27 CEST 2010: user.home=C:\Users\Lavoro
Wed Aug 25 10:58:27 CEST 2010: user.dir=C:\sviluppo\Developer_Edition_6.6_windows_sql
Wed Aug 25 10:58:27 CEST 2010: [NATIVE_ENVIRONMENT]
Wed Aug 25 10:58:27 CEST 2010: ALLUSERSPROFILE=C:\ProgramData
Wed Aug 25 10:58:27 CEST 2010: APPDATA=C:\Users\Lavoro\AppData\Roaming
Wed Aug 25 10:58:27 CEST 2010: CommonProgramFiles=C:\Program Files\Common Files
Wed Aug 25 10:58:27 CEST 2010: COMPUTERNAME=PC-LUCA
Wed Aug 25 10:58:27 CEST 2010: ComSpec=C:\Windows\system32\cmd.exe
Wed Aug 25 10:58:27 CEST 2010: FP_NO_HOST_CHECK=NO
Wed Aug 25 10:58:27 CEST 2010: HOMEDRIVE=C:
Wed Aug 25 10:58:27 CEST 2010: HOMEPATH=\Users\Lavoro
Wed Aug 25 10:58:27 CEST 2010: JAVA_HOME=C:\Users\Lavoro\AppData\Local\Temp\LRE3AAF.tmp
Wed Aug 25 10:58:27 CEST 2010: JRE_HOME=C:\sviluppo\jre1.5.0_16\bin
Wed Aug 25 10:58:27 CEST 2010: LOCALAPPDATA=C:\Users\Lavoro\AppData\Local
Wed Aug 25 10:58:27 CEST 2010: LOGONSERVER=\\PC-LUCA
Wed Aug 25 10:58:27 CEST 2010: NUMBER_OF_PROCESSORS=2
Wed Aug 25 10:58:27 CEST 2010: OS=Windows_NT
Wed Aug 25 10:58:27 CEST 2010: Path=C:\sviluppo\Documentum\Shared;C:\Program Files\PC Connectivity Solution\;C:\sviluppo\oracle\product\10.2.0\db_1\bin;C:\sviluppo\CollabNet Subversion Client;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\;C:\Windows\System32\WindowsPowerShell\v1.0\;c:\sviluppo\ant\bin;C:\Program Files\Common Files\Adobe\AGL;c:\sviluppo\nano;C:\sviluppo\maven\apache-maven-2.2.1\bin;c:\sviluppo\Microsoft SQL Server\90\Tools\binn\
Wed Aug 25 10:58:27 CEST 2010: PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
Wed Aug 25 10:58:27 CEST 2010: PROCESSOR_ARCHITECTURE=x86
Wed Aug 25 10:58:27 CEST 2010: PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 13, GenuineIntel
Wed Aug 25 10:58:27 CEST 2010: PROCESSOR_LEVEL=6
Wed Aug 25 10:58:27 CEST 2010: PROCESSOR_REVISION=0f0d
Wed Aug 25 10:58:27 CEST 2010: ProgramData=C:\ProgramData
Wed Aug 25 10:58:27 CEST 2010: ProgramFiles=C:\Program Files
Wed Aug 25 10:58:27 CEST 2010: PUBLIC=C:\Users\Public
Wed Aug 25 10:58:27 CEST 2010: RoxioCentral=C:\Program Files\Common Files\Roxio Shared\9.0\Roxio Central33\
Wed Aug 25 10:58:27 CEST 2010: SystemDrive=C:
Wed Aug 25 10:58:27 CEST 2010: SystemRoot=C:\Windows
Wed Aug 25 10:58:27 CEST 2010: TEMP=C:\Users\Lavoro\AppData\Local\Temp
Wed Aug 25 10:58:27 CEST 2010: TMP=C:\Users\Lavoro\AppData\Local\Temp
Wed Aug 25 10:58:27 CEST 2010: USERDOMAIN=PC-Luca
Wed Aug 25 10:58:27 CEST 2010: USERNAME=Lavoro
Wed Aug 25 10:58:27 CEST 2010: USERPROFILE=C:\Users\Lavoro
Wed Aug 25 10:58:27 CEST 2010: VISUALSVN_SERVER=C:\Program Files\VisualSVN Server\
Wed Aug 25 10:58:27 CEST 2010: windir=C:\Windows
Wed Aug 25 10:58:27 CEST 2010: __APPCOMPAT_MANIFEST=
Wed Aug 25 10:58:27 CEST 2010: __COMPAT_LAYER=VistaSetUp
Wed Aug 25 10:58:27 CEST 2010: [SERVER]
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM=C:\sviluppo\DocumentumData
Wed Aug 25 10:58:27 CEST 2010: CREATE_DESKTOP_ICONS=FALSE
Wed Aug 25 10:58:27 CEST 2010: PRESERVE_DATA_DOCBASE_DIR=TRUE
Wed Aug 25 10:58:27 CEST 2010: SECURE.USER_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.INSTALL_OWNER_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: DOCBASE_NAME=document
Wed Aug 25 10:58:27 CEST 2010: DOCBASE_ID=214263
Wed Aug 25 10:58:27 CEST 2010: USE_PRECANNED_DATA_FILE=FALSE
Wed Aug 25 10:58:27 CEST 2010: DATABASE_ADMIN_NAME=sa
Wed Aug 25 10:58:27 CEST 2010: DOCBROKER_PORT=1489
Wed Aug 25 10:58:27 CEST 2010: DOCBASE_SERVICE_NAME=documentum
Wed Aug 25 10:58:27 CEST 2010: SECURE.DATABASE_ADMIN_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.DATABASE_ADMIN_PASSWORD_CONFIRM=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.BOF_REGISTRY_USER_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.BOF_REGISTRY_USER_PASSWORD_CONFIRM=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.DOCBASE_OWNER_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: SECURE.DOCBASE_OWNER_PASSWORD_CONFIRM=******
Wed Aug 25 10:58:27 CEST 2010: DOCBROKER_NAME=Docbroker
Wed Aug 25 10:58:27 CEST 2010: SMTP_SERVER_NAME=localhost
Wed Aug 25 10:58:27 CEST 2010: ENABLE_TCS=FALSE
Wed Aug 25 10:58:27 CEST 2010: TCS_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_CAS=FALSE
Wed Aug 25 10:58:27 CEST 2010: CAS_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_RPS=FALSE
Wed Aug 25 10:58:27 CEST 2010: RPS_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_RM=FALSE
Wed Aug 25 10:58:27 CEST 2010: RM_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_PRM=FALSE
Wed Aug 25 10:58:27 CEST 2010: PRM_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_AS=FALSE
Wed Aug 25 10:58:27 CEST 2010: AS_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_XHIVE=FALSE
Wed Aug 25 10:58:27 CEST 2010: XHIVE_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_CSSL=FALSE
Wed Aug 25 10:58:27 CEST 2010: CSSL_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_STA=FALSE
Wed Aug 25 10:58:27 CEST 2010: STA_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: ENABLE_FRS=FALSE
Wed Aug 25 10:58:27 CEST 2010: FRS_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM_HOME=C:\sviluppo\DocumentumData\product\6.6
Wed Aug 25 10:58:27 CEST 2010: DATA_FOLDER_DIRECTORY=C:\sviluppo\DocumentumData\data
Wed Aug 25 10:58:27 CEST 2010: TOMCAT_HTTP_PORT=
Wed Aug 25 10:58:27 CEST 2010: METHOD_SERVER_SERVICE_AUTO_START=FALSE
Wed Aug 25 10:58:27 CEST 2010: RUN_CONFIGURATION_PROGRAM=FALSE
Wed Aug 25 10:58:27 CEST 2010: LOG_FILE_NAME=C:\sviluppo\Developer_Edition_6.6_windows_sql\Lavoro.ServerInstaller.log
Wed Aug 25 10:58:27 CEST 2010: OS_NAME=Windows Vista
Wed Aug 25 10:58:27 CEST 2010: SERVER_INSTALL_TIME=Wed Aug 25 10:45:56 CEST 2010
Wed Aug 25 10:58:27 CEST 2010: OS_VERSION=6.0
Wed Aug 25 10:58:27 CEST 2010: OS_LANGUAGE=it
Wed Aug 25 10:58:27 CEST 2010: LOCAL_MACHINE_NAME=PC-Luca
Wed Aug 25 10:58:27 CEST 2010: DATABASE_TYPE=SQLServer
Wed Aug 25 10:58:27 CEST 2010: TEMP_DOCUMENTUM=C:\sviluppo\DocumentumData
Wed Aug 25 10:58:27 CEST 2010: PLATFORM=UNKOWN
Wed Aug 25 10:58:27 CEST 2010: INSTALL_TIME=25-ago-2010 10.45.56
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM_DBA=C:\sviluppo\DocumentumData\dba
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM_DATA=C:\sviluppo\DocumentumData\data
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM_SHARE=C:\sviluppo\DocumentumData\share
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTUM_SDK=C:\sviluppo\DocumentumData\share\sdk
Wed Aug 25 10:58:27 CEST 2010: CONFIGURE_HOME=C:\sviluppo\DocumentumData\product\6.6\install
Wed Aug 25 10:58:27 CEST 2010: SERVER_EXISTING_VERSION=6.6
Wed Aug 25 10:58:27 CEST 2010: OLD_DOCUMENTUM_HOME=
Wed Aug 25 10:58:27 CEST 2010: OLD_CONFIGURE_HOME=
Wed Aug 25 10:58:27 CEST 2010: SERVER_UPGRADE=FALSE
Wed Aug 25 10:58:27 CEST 2010: TCS_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: AS_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: XHIVE_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: CAS_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: CSSL_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: STA_STATUS=OFF
Wed Aug 25 10:58:27 CEST 2010: JAVA_METHOD_LOCATION=C:\sviluppo\DocumentumData\dba\java_methods
Wed Aug 25 10:58:27 CEST 2010: TOMCAT_METHOD_LOCATION=C:\sviluppo\DocumentumData\dba\java_methods
Wed Aug 25 10:58:27 CEST 2010: JMS_TOOL_LIB=C:\sviluppo\DocumentumData\product\6.6\lib
Wed Aug 25 10:58:27 CEST 2010: KEYSTORE_FILE=C:\sviluppo\DocumentumData\dba\secure\aek.key
Wed Aug 25 10:58:27 CEST 2010: KEYSTORE_STATUS=NOT_EXIST
Wed Aug 25 10:58:27 CEST 2010: USE_DEFAULT_KS_PASSWORD=TRUE
Wed Aug 25 10:58:27 CEST 2010: ENABLE_STORAGE_AWARE=
Wed Aug 25 10:58:27 CEST 2010: STORAGE_AWARE_LICENSE=
Wed Aug 25 10:58:27 CEST 2010: SECURE.KEYSTORE_PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: [INDEX_AGENT]
Wed Aug 25 10:58:27 CEST 2010: INDEX_AGENT_TYPE=LUCENE
Wed Aug 25 10:58:27 CEST 2010: EMBEDDED_INDEX_AGENT=TRUE
Wed Aug 25 10:58:27 CEST 2010: INDEX_AGENT_CONFIGURATION_PROGRAM_NAME=IndexAgent_Configuration_Program.bin
Wed Aug 25 10:58:27 CEST 2010: INDEX_AGENT_HOME=C:\sviluppo\Documentum\IndexAgents
Wed Aug 25 10:58:27 CEST 2010: [SERVER_UTIL]
Wed Aug 25 10:58:27 CEST 2010: SERVER_CONFIGURATOR_GLOBAL_CONTEXT_INI=C:\Users\Lavoro\AppData\Local\Temp\serverRecorded5825037852486767186.ini
Wed Aug 25 10:58:27 CEST 2010: INDEX_AGENT_CONFIGURATOR_GLOBAL_CONTEXT_INI=C:\Users\Lavoro\AppData\Local\Temp\indexAgentRecorded3431355918685564177.ini
Wed Aug 25 10:58:27 CEST 2010: [OEM]
Wed Aug 25 10:58:27 CEST 2010: TEMP_DIRECTORY=C:\sviluppo\Developer_Edition_6.6_windows_sql\temp
Wed Aug 25 10:58:27 CEST 2010: SHOW_USER_INPUT_PANEL=TRUE
Wed Aug 25 10:58:27 CEST 2010: DEFAULT_PROGRAM_DIR=C:\Program Files\Documentum
Wed Aug 25 10:58:27 CEST 2010: DEFAULT_USER_DIR=C:\Documentum
Wed Aug 25 10:58:27 CEST 2010: USE_OEM_CONFIG_XML_FILE=FALSE
Wed Aug 25 10:58:27 CEST 2010: DATABASE_TYPE=mssql
Wed Aug 25 10:58:27 CEST 2010: ASK_EXISTING_DATABASE_INFO=No, I want to use my existing Microsoft SQL Server database.
Wed Aug 25 10:58:27 CEST 2010: SHOW_ADVANCED_OPTIONS_PANEL=Yes
Wed Aug 25 10:58:27 CEST 2010: EXTERNAL_DB=TRUE
Wed Aug 25 10:58:27 CEST 2010: VALIDATION_FAILURE_MSG=
Wed Aug 25 10:58:27 CEST 2010: VALIDATION_SUCCESS=TRUE
Wed Aug 25 10:58:27 CEST 2010: START_OEM_SERVICE=TRUE
Wed Aug 25 10:58:27 CEST 2010: ENABLE_DB_COMPONENT=false
Wed Aug 25 10:58:27 CEST 2010: NO_PRECANNED_DATA_FILE=TRUE
Wed Aug 25 10:58:27 CEST 2010: RUN_SYBASE=FALSE
Wed Aug 25 10:58:27 CEST 2010: [FEEDBACK]
Wed Aug 25 10:58:27 CEST 2010: LAST_BEAN_INVOKED=DiWAOemExecuteConfigurationScripts
Wed Aug 25 10:58:27 CEST 2010: LAST_BEAN_ID_INVOKED=executeConfigurationScripts
Wed Aug 25 10:58:27 CEST 2010: LAST_BEAN_STATUS=FAIL
Wed Aug 25 10:58:27 CEST 2010: LAST_BEAN_MESSAGE=An exception occured in: DiWAOemExecuteConfigurationScripts, beanID: executeConfigurationScripts - DiWAOemExecuteConfigurationScripts failed! - 'Creating connection broker and repository ' failed.; Runtime execution failed with child process "C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\launchServerConfigurationProgram.bat -passwords databaseAdmin=<hidden> docbaseOwner=<hidden> windowsInstallOwner=<hidden> globalRegistryUser=<hidden> -config C:\sviluppo\Developer_Edition_6.6_windows_sql\temp\config_docbase.ini -record C:\Users\Lavoro\AppData\Local\Temp\serverRecorded5825037852486767186.ini -silent " exit code of 1
Wed Aug 25 10:58:27 CEST 2010: OBJECT_DUMP=com.documentum.install.oem.common.beans.wizard.action.DiWAOemExecuteConfigurationScripts: globalWizardServices=com.installshield.wizard.service.LocalWizardServices@634bec, actionsFilePath=$A(BEAUTY_MAIN)/oem/installConfig/oemActions.xml, actionsMapFilePath=$A(BEAUTY_MAIN)/oem/installConfig/oemActionsMap.xml, com.documentum.install.shared.common.services.DiAsynchronousWizardAction: MESSAGE=1, QUESTION=2, WARNING=3, ERROR=4, endTime=0, estimateTime=0, EXCLUDE_DIRS=beans;test;abstractClasses, failMessage=DiWAOemExecuteConfigurationScripts failed!, failAction=1, isUninstaller=false, class$com$documentum$install$shared$common$services$DiMessageDialog=null, ajc$tjp_0=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getClassName()), ajc$tjp_1=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.setFailMessage(String)), ajc$tjp_2=call(Class com.documentum.install.shared.common.services.DiAsynchronousWizardAction.class$(String)), ajc$tjp_3=call(Wizard com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getWizard()), ajc$tjp_4=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.handleBuildException(WizardBuilderSupport, Exception)), ajc$tjp_5=call(boolean com.documentum.install.shared.common.services.DiUtil.hasInstallFailed()), ajc$tjp_6=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getClassName()), ajc$tjp_7=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getBeanId()), ajc$tjp_8=call(void com.documentum.install.shared.common.services.DiUtil.setLastBeanStatus(String, String, String)), ajc$tjp_9=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.handleRuntimeException(Exception, String, int)), ajc$tjp_10=call(Service com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getService(String)), ajc$tjp_11=call(com.documentum.install.shared.common.error.DiException(Throwable)), ajc$tjp_12=call(Service com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getService(String)), ajc$tjp_13=call(com.documentum.install.shared.common.error.DiException(Throwable)), ajc$tjp_14=call(String com.documentum.install.shared.common.services.DiUtil.stripPackage(String)), ajc$tjp_15=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getUIMode()), ajc$tjp_16=call(Frame com.documentum.install.shared.common.services.DiUtil.getTopLevelFrame()), ajc$tjp_17=call(Wizard com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getWizard()), ajc$tjp_18=call(void com.documentum.install.shared.common.services.DiUtil.setTopLevelFrame(Frame)), ajc$tjp_19=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_20=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_21=call(void com.documentum.install.shared.common.services.DiUtil.displayAWTUserMessage(String, String)), ajc$tjp_22=call(WizardServices com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getServices()), ajc$tjp_23=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_24=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_25=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getUIMode()), ajc$tjp_26=call(Wizard com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getWizard()), ajc$tjp_27=call(void com.documentum.install.shared.common.services.DiUtil.setTopLevelFrame(Frame)), ajc$tjp_28=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_29=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_30=call(String com.documentum.install.shared.common.services.DiUtil.getAWTUserInput(String, String, String[], String)), ajc$tjp_31=call(WizardServices com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getServices()), ajc$tjp_32=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_33=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_34=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.setFailAction(int)), ajc$tjp_35=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.setFailMessage(String)), ajc$tjp_36=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.handleRuntimeException(Exception)), ajc$tjp_37=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.resolveString(String)), ajc$tjp_38=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getClassName()), ajc$tjp_39=call(String com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getBeanId()), ajc$tjp_40=call(WizardServices com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getServices()), ajc$tjp_41=call(String com.documentum.install.shared.common.services.DiUtil.toString(Object)), ajc$tjp_42=call(String com.documentum.install.shared.common.error.DiExceptionHandler.handleException(Exception, String, String, String, int, WizardServices, String, String, boolean)), ajc$tjp_43=call(boolean com.documentum.install.shared.common.services.DiUtil.isEmpty(String)), ajc$tjp_44=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.displayUserMessage(String, String, int)), ajc$tjp_45=call(Service com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getService(String)), ajc$tjp_46=call(Wizard com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getWizard()), ajc$tjp_47=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.logEvent(Object, String, Object)), ajc$tjp_48=call(void com.documentum.install.shared.common.services.DiAsynchronousWizardAction.putSharedClasses(WizardBuilderSupport, File, int)), ajc$tjp_49=call(Wizard com.documentum.install.shared.common.services.DiAsynchronousWizardAction.getWizard()), com.installshield.wizard.AsynchronousWizardAction: progressRenderer=com.installshield.wizardx.progress.StandardProgressRenderer@13d95a6, panelId=null, useCustomPanel=false, class$com$installshield$wizard$ProgressRenderer=null, com.installshield.wizard.WizardAction: state=Configuring Content Server - Creating connection broker and repository (44% Complete), com.installshield.wizard.WizardBean: TEMPLATE_VALUE=1, CURRENT_VALUE=2, nextId=691, beanId=executeConfigurationScripts, displayName=Di WA Oem Execute Configuration Scripts, active=true, conditionSet=com.installshield.util.ConditionSet@1db73b1, extendedProperties={}, comments=, conditionOperator=AND, buildCategories=, parent=null, node=Di WA Oem Execute Configuration Scripts (executeConfigurationScripts), tree=com.installshield.wizard.WizardTree@886a6a, wizard=com.installshield.wizard.Wizard@28dd7, values={}
Wed Aug 25 10:58:27 CEST 2010: [DBSERVER]
Wed Aug 25 10:58:27 CEST 2010: CONNECTION_NAME=documentum
Wed Aug 25 10:58:27 CEST 2010: SYBASE_SERVER_PORT=5000
Wed Aug 25 10:58:27 CEST 2010: SYBASE_SERVER_NAME=documentum
Wed Aug 25 10:58:27 CEST 2010: INSTALL_LOCATION=C:\sviluppo\DocumentumData\mssql
Wed Aug 25 10:58:27 CEST 2010: [APPSERVER]
Wed Aug 25 10:58:27 CEST 2010: SERVER_HTTP_PORT=9080
Wed Aug 25 10:58:27 CEST 2010: # method server http port
Wed Aug 25 10:58:27 CEST 2010: USERNAME=admin
Wed Aug 25 10:58:27 CEST 2010: SECURE.PASSWORD=******
Wed Aug 25 10:58:27 CEST 2010: JMX_PORT=9081
Wed Aug 25 10:58:27 CEST 2010: JMX_PORT_CONNECTOR=9099
Wed Aug 25 10:58:27 CEST 2010: [DFC]
Wed Aug 25 10:58:27 CEST 2010: DOCUMENTATION_FEATURE=FALSE
Wed Aug 25 10:58:27 CEST 2010: PIA_INSTALLER_FEATURE=FALSE
Wed Aug 25 10:58:27 CEST 2010: DOCBROKER_HOST=PC-LUCA
Wed Aug 25 10:58:27 CEST 2010: DISPLAY_MINOR_VERSION=6.6
Wed Aug 25 10:58:27 CEST 2010: DISPLAY_MAINTENANCE_VERSION=6.6.0
Wed Aug 25 10:58:27 CEST 2010: DISPLAY_FULL_VERSION=6.6.0 (Build 39)
Wed Aug 25 10:58:27 CEST 2010: VERSION=6.6.0.39
Wed Aug 25 10:58:27 CEST 2010: DJCB_PATH=
Wed Aug 25 10:58:27 CEST 2010: DJCB_CLASS_PATH=
Wed Aug 25 10:58:27 CEST 2010: DJCB_VM_ARGS=
Wed Aug 25 10:58:27 CEST 2010: DJCB_JAVA_VM=
Wed Aug 25 10:58:27 CEST 2010: DCTM_CHECKOUT_DIR=C:\sviluppo\DocumentumData\Checkout
Wed Aug 25 10:58:27 CEST 2010: DCTM_EXPORT_DIR=C:\sviluppo\DocumentumData\Export
Wed Aug 25 10:58:27 CEST 2010: APPTOKEN_DIR=C:\sviluppo\DocumentumData\apptoken
Wed Aug 25 10:58:27 CEST 2010: DFC_APPTOKEN_GENERIC_DIR=C:/sviluppo/DocumentumData/apptoken
Wed Aug 25 10:58:27 CEST 2010: DFC_DATA_DIR=C:\sviluppo\DocumentumData
Wed Aug 25 10:58:27 CEST 2010: DFC_DATA_CANONICAL_DIR=C:/sviluppo/DocumentumData
Wed Aug 25 10:58:27 CEST 2010: DFC_DATA_GENERIC_DIR=C:/sviluppo/DocumentumData
Wed Aug 25 10:58:27 CEST 2010: DCTM_REG_FILE_PATH=C:\sviluppo\DocumentumData\documentum.ini
Wed Aug 25 10:58:27 CEST 2010: [DFC_BUILD]
Wed Aug 25 10:58:27 CEST 2010: YEAR=2010
Wed Aug 25 10:58:27 CEST 2010: [SERVER_BUILD]
Wed Aug 25 10:58:27 CEST 2010: VERSION=6.6.0.041
Wed Aug 25 10:58:27 CEST 2010: DM_SERVER_VERSION=6.6
Wed Aug 25 10:58:27 CEST 2010: [TCF]
Wed Aug 25 10:58:27 CEST 2010: VERSION=5.3.0.000
err: ---- END "Global Context: " output ---- (Wed Aug 25 10:58:27 CEST 2010)
