Hi all,
I have some doubts in creating custom adaptors.
1. To compile the java program(adaptor java program), i need to import the abstract classes and interfaces which are in the package - com.documentum.xforms.engine.adaptor , which i guess is in the XformsEngine.jar file. However, my doubt is, to unjar it, wht is the procedure i need to follow (?) considering XformsEngine.jar file is present in the - C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\da\WEB-INF\lib folder.
2. Once i have compiled and got the java class(custom adaptor), where do i need to place it ( in which folder)
3. How can we obtain the dates inputted by the user on a form and write a code for an adaptor to calculate the difference between 2 dates.
Thank you,
Namrata
