Hi all,
I try to write SOAP web services over DFS, and I have a problem with get object by path if I do the following process:
- Create path with IObjectService.createPath(...) and I get the ObjectId (id1) of the last created folder
- Get the created path with IObjectService.get() by an ObjectPath
- Delete this path (by repoint or IObjectServie.delete(...) )
- Create the same path with IObjectService.createPath(...) and I get a new ObjectId (id2) of the last created folder
- Get the path with IObjectService.get() by an ObjectPath
The last Get make an error because it try to get the folder properties by the first ObjectId (id1) :
Caused by: com.emc.documentum.fs.services.core.CoreServiceException: Operation output generation failed: could not retrieve data for identity: 0b02c181800b4a5e.
at com.emc.documentum.fs.services.core.impl.execution.proto.transformation.CoreServiceExceptionContext.execute(CoreServiceExceptionContext.java:31)
at com.emc.documentum.fs.services.core.impl.execution.proto.payload.FailOnExceptionPayloadPolicy.execute(FailOnExceptionPayloadPolicy.java:28)
at com.emc.documentum.fs.services.core.impl.execution.proto.payload.PayloadPolicy.execute(PayloadPolicy.java:33)
at com.emc.documentum.fs.services.core.impl.execution.proto.payload.PayloadPolicy.execute(PayloadPolicy.java:1)
at com.emc.documentum.fs.services.core.impl.execution.proto.transformation.ObjectIdentitySetToDataPackagePayloadAdapter.execute(ObjectIdentitySetToDataPackagePayloadAdapter.java:29)
at com.emc.documentum.fs.services.core.impl.ObjectService.get(ObjectService.java:395)
at com.emc.documentum.kw.common.services.ObjectService.superGet(ObjectService.java:195)
at com.emc.documentum.kw.common.services.ObjectService.get(ObjectService.java:171)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.emc.documentum.fs.rt.context.impl.compat.ClientReflectionServiceInvokerCompat60.invoke(ClientReflectionServiceInvokerCompat60.java:51)
at com.emc.documentum.fs.rt.impl.tx.TxInvocationHandler.invoke(TxInvocationHandler.java:29)
at com.emc.documentum.fs.rt.context.impl.ReturnedContentTransformationHandler.invoke(ReturnedContentTransformationHandler.java:45)
at com.emc.documentum.fs.rt.context.impl.OperationOptionsHandler.invoke(OperationOptionsHandler.java:71)
at com.emc.documentum.fs.rt.context.impl.ServiceContextCleanupHandler.invoke(ServiceContextCleanupHandler.java:30)
at com.emc.documentum.fs.rt.context.impl.ContextThreadLocalInvocationHandler.invoke(ContextThreadLocalInvocationHandler.java:51)
at com.emc.documentum.fs.rt.context.impl.ServiceContextInvocationHandler.invoke(ServiceContextInvocationHandler.java:30)
at $Proxy101.get(Unknown Source)
at com.bycn.vega.services.core.CommonServiceImpl.getObject(CommonServiceImpl.java:122)
at com.bycn.vega.services.core.CommonServiceImpl.getObjectByPath(CommonServiceImpl.java:80)
... 45 more
Caused by: com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DfcOperationException: Failed to retrieve relations from docbrocker
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DeepGetAction.execute(DeepGetAction.java:157)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DeepGetAction.execute(DeepGetAction.java:1)
at com.emc.documentum.fs.services.core.impl.execution.proto.transformation.DataObjectToObjectIdentityAdapter.execute(DataObjectToObjectIdentityAdapter.java:22)
at com.emc.documentum.fs.services.core.impl.execution.proto.transformation.DataObjectToObjectIdentityAdapter.execute(DataObjectToObjectIdentityAdapter.java:1)
at com.emc.documentum.fs.services.core.impl.execution.proto.transformation.CoreServiceExceptionContext.execute(CoreServiceExceptionContext.java:27)
... 66 more
Caused by: com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DfcOperationException: E_CANNOT_LOAD_PROPERTIES
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PropertiesLoader.process(PropertiesLoader.java:64)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PropertiesLoader.execute(PropertiesLoader.java:40)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PropertiesLoader.execute(PropertiesLoader.java:1)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PermissionsLoader.execute(PermissionsLoader.java:38)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PermissionsLoader.execute(PermissionsLoader.java:1)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DeepGetAction.walk(DeepGetAction.java:252)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DeepGetAction.execute(DeepGetAction.java:141)
... 70 more
Caused by: com.emc.documentum.fs.services.core.impl.execution.proto.dfc.DfcOperationException: Getting persistent object failed. Repository: "VEGA".
at com.emc.documentum.fs.services.core.impl.execution.proto.util.GetIdUtil.getPersistentObject(GetIdUtil.java:147)
at com.emc.documentum.fs.services.core.impl.execution.proto.dfc.PropertiesLoader.process(PropertiesLoader.java:55)
... 76 more
Caused by: DfIdNotFoundException:: THREAD: 13902059@qtp-7588881-0; MSG: [DM_API_E_EXIST]error: "Document/object specified by 0b02c181800b4a5e does not exist."; ERRORCODE: 100; NEXT: null
at com.documentum.fc.client.impl.docbase.DocbaseExceptionMapper.newException(DocbaseExceptionMapper.java:49)
at com.documentum.fc.client.impl.connection.docbase.MessageEntry.getException(MessageEntry.java:39)
at com.documentum.fc.client.impl.connection.docbase.DocbaseMessageManager.getException(DocbaseMessageManager.java:137)
at com.documentum.fc.client.impl.connection.docbase.netwise.NetwiseDocbaseRpcClient.checkForMessages(NetwiseDocbaseRpcClient.java:305)
at com.documentum.fc.client.impl.connection.docbase.netwise.NetwiseDocbaseRpcClient.applyForObject(NetwiseDocbaseRpcClient.java:648)
at com.documentum.fc.client.impl.connection.docbase.DocbaseConnection$8.evaluate(DocbaseConnection.java:1286)
at com.documentum.fc.client.impl.connection.docbase.DocbaseConnection.evaluateRpc(DocbaseConnection.java:1054)
at com.documentum.fc.client.impl.connection.docbase.DocbaseConnection.applyForObject(DocbaseConnection.java:1278)
at com.documentum.fc.client.impl.docbase.DocbaseApi.parameterizedFetch(DocbaseApi.java:107)
at com.documentum.fc.client.impl.objectmanager.PersistentDataManager.fetchFromServer(PersistentDataManager.java:201)
at com.documentum.fc.client.impl.objectmanager.PersistentDataManager.getData(PersistentDataManager.java:92)
at com.documentum.fc.client.impl.objectmanager.PersistentObjectManager.getObjectFromServer(PersistentObjectManager.java:355)
at com.documentum.fc.client.impl.objectmanager.PersistentObjectManager.getObject(PersistentObjectManager.java:311)
at com.documentum.fc.client.impl.session.Session.getObject(Session.java:844)
at com.documentum.fc.client.impl.session.SessionHandle.getObject(SessionHandle.java:583)
at com.emc.documentum.fs.services.core.impl.execution.proto.util.GetIdUtil.getPersistentObject(GetIdUtil.java:143)
... 77 more
Caused by: DfException:: THREAD: 13902059@qtp-7588881-0; MSG: [DM_SYSOBJECT_E_CANT_FETCH_INVALID_ID]error: "Cannot fetch a sysobject - Invalid object ID : 0b02c181800b4a5e"; ERRORCODE: 100; NEXT: null
... 93 more
When I reboot my server, I get the good Id (id2) and no exception occur.
Is this problem caused by my DFS or DFC cache configuration ?
