Hi all,
Did someone encounter the following problem ?
13:36:29,517 ERROR [Twiddle] Exec failed
org.jboss.util.NestedRuntimeException: Could not obtain connection to any of these urls: XCPSERVER:9084; - nested throwable: (javax.naming.CommunicationException: Could not obtain connection to any of these urls: XCPSERVER:9084 [Root exception is javax.naming.CommunicationException: Failed to connect to server XCPSERVER:9084 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server XCPSERVER:9084 [Root exception is java.net.ConnectException: Connection refused: connect]]])
at org.jboss.console.twiddle.Twiddle$1.getServer(Twiddle.java:143)
at org.jboss.console.twiddle.command.MBeanServerCommand.getMBeanServer(MBeanServerCommand.java:59)
at org.jboss.console.twiddle.command.GetCommand.execute(GetCommand.java:149)
at org.jboss.console.twiddle.Twiddle.main(Twiddle.java:305)
Caused by: javax.naming.CommunicationException: Could not obtain connection to any of these urls: XCPSERVER:9084 [Root exception is javax.naming.CommunicationException: Failed to connect to server XCPSERVER:9084 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server XCPSERVER:9084 [Root exception is java.net.ConnectException: Connection refused: connect]]]
at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1416)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:596)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:589)
at javax.naming.InitialContext.lookup(InitialContext.java:351)
at org.jboss.console.twiddle.Twiddle.createMBeanServerConnection(Twiddle.java:250)
at org.jboss.console.twiddle.Twiddle.connect(Twiddle.java:268)
at org.jboss.console.twiddle.Twiddle.access$300(Twiddle.java:62)
at org.jboss.console.twiddle.Twiddle$1.getServer(Twiddle.java:139)
... 3 more
Caused by: javax.naming.CommunicationException: Failed to connect to server XCPSERVER:9084 [Root exception is javax.naming.ServiceUnavailableException: Failed to connect to server XCPSERVER:9084 [Root exception is java.net.ConnectException: Connection refused: connect]]
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:269)
at org.jnp.interfaces.NamingContext.checkRef(NamingContext.java:1387)
... 10 more
Caused by: javax.naming.ServiceUnavailableException: Failed to connect to server XCPSERVER:9084 [Root exception is java.net.ConnectException: Connection refused: connect]
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:243)
... 11 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:519)
at java.net.Socket.connect(Socket.java:469)
at java.net.Socket.<init>(Socket.java:366)
at java.net.Socket.<init>(Socket.java:266)
at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:84)
at org.jnp.interfaces.TimedSocketFactory.createSocket(TimedSocketFactory.java:77)
at org.jnp.interfaces.NamingContext.getServer(NamingContext.java:239)
... 11 more
I'm running Documentum xCP 1.0 Developer Edition under Windows XP SP3 and this problem is stopping JBoss. Everything else works perfectly.
Thus, I can't access TaskSpace and DA.
