Hi Experts,
I have installed brava and I get this message.
IGC Brava! Enterprise for TaskSpace does not work on web browsers other than Internet Explorer!
actually I am using IE.
please help
If there are Accepted Answers, those will be shown by default. You can switch to 'All Replies' by selecting the tab below.
6.2 is the one we have installed.
Are you using a supported IE version that is listed in the release notes of the Brava?
Don't know..
Johnny,
do you know which version is supported? I don't have the release notes, and don't know where I can find it.
Which version of Brava are you using?
Hi Johnny,
I have Brava6TaskSpace65 and I have installed it on taskspace 6.7.
Yesterday I had been getting the same message in fact then I have found out that nothing had been installed and this message occurs if you choose brava as a document viewer.It does not matter whether you have installed brava or not.
But today I have installed it correctly and it is responding when I try to open a new document.It installs a plugin as I click to open a document, then waits for some time and again this message appears.Cant understand what is wrong.
So maybe this is because I have installed it on TSP 6.7sp1.
Do you know where I can get brava for TSP 6.7.sp1 or if I install taskspace 6.5 on a 6.7 sp1 repository, would it work?
thanks in advance
I think there is a newer version of Brava that is supported for 6.7. We installed Brava for Taskspace 6.7 and havent had any problems with it.
Yes, Johnny there is a new version brava.Currently I have Brava 6.015 also I have found Brava 6.2 I guess this one is the new version but not sure.Could you please let me know what version was your brava?
Thank you very much, I hope it will fix the problem.
yes, this one worked without any problems.But there is brava 7 as well.The latest one is brava 7.
Since Brava (Intergraph) supports multiple ECM vendors, there will always be a newer version of their product than the one that is integrated with xCP/Webtop.
Johnny, not Intergraph but Informative Graphics
In fact this one is for taskspace. I mean the latest brava for taskspace is brava 7.
Thanks for correcting me Francois - brain slip
