I am looking for code template and procedure to create an automatic method for auto-performer in a Workflow. Please post the same if you can.
Please share your knowledge and experience.
Thanks.
ta
If there are Accepted Answers, those will be shown by default. You can switch to 'All Replies' by selecting the tab below.
public class TestWorkflowMethod extends WorkflowMethod {
protected int doTask (IDfWorkitem workitem,
IDfProperties iDfProperties,
PrintWriter printWriter) throws Exception
IDfWorkitemEx witem = (IDfWorkitemEx)workitem;
... // my custom implementation
You need to implement a method class based on WorkflowMethod class. Then create a dm_method with this class as verb. You will need bmp_infra.jar for compilation.
It could be also packaged as a module, you need then implement IDfModule interface.
Xiangang
Thanks Xiangang.
We are currently still using Workflow Manager to build workflow templates. Do you think the workflow method template still works? Can you please give me more details about how to code/compile (like using Composer etc.) and how to attach this method to the workflow template etc.
Thank you very much for your help.
