What is xCP? Is it a separate product? Does it go with Process Engine? Do we need a separate License key to install it? Do you think using xCP has more advantages in designing Workflow templates? Is xCP a separate documentum product? Does it go with Process Builder/Process Engine? Please give me more info and the documentation where I can find the info. Do we need a License key to install xCP? Where I need to install it? on Content Server box or on my developer machine? I have so many questions.
I found xCP Best Prctices guide in product download (subscribernet) under Process Builder. I am reading it currently. However I did not find the xCP software under Process Builder.
Please share your knowledge and experiences for figuring this out.
Thanks.
ta
