Hi, everyone.
I have problem using ActionService execute method.
I have an action named customaction . This action open an container dialog container which its container component calls CustomContainer class (extends DialogContainer) ...
In CustomContainer class I want execute two actions ( myexportrenditionaction and checkout ) . I have created myexportrenditionaction and its call custom container class. myexportrenditionaction action export document rendition to the client which client user not select destination directory, because custom class select directory automatically (for example: String destDirectory = "C:\\temp\\test") . it works well. there is not any problem. and chekout action is work too.
There is no problem with actions. They work separately. but I want execute this actions in the same method or the same time. However when I place those actions in the same method together the method execution fails. How can I execute they together?
in CustomContainer class onInit method :
public void onInit(ArgumentList args) {
super.onInit(args);
String id = args.get("objectId"); // document id
ArgumentList rendArgs;
rendArgs.add("objectId", id);
rendArgs.add("contentType", "xml");
ArgumentList checkoutArgs;
checkoutArgs.add("objectId", id);
// ActionService.execute("myexportrenditionaction", rendArgs, getContext(), this,null);
// ActionService.execute("checkout", checkoutArgs, getContext(), this,null);
There is no problem with actions, problem is that how can I execute them together?
