Hi All,
One of my users id getting an exception :
class com.documentum.web.contentxfer.ucf.UcfSessionManager$ClientException.
These are my client system spcecifications:
Webtop version : 5.3.0.317
java version : 1.7.0_05
Windows 7 system
This seems to be an UCF exception.As per the post on powerlink ,I made the following changes to the clients local system:
1. unchecking in the Java Control Panel the option for 'Enable the next generation Java Plug-In'
2. clearing Java cache
3. temp files
4.deleting UCF folders
5.deleting EMC certificate
6.cleaning IE cache
7.restarting the browser
When this does not work ...I tried doing this...
Enable (in file C:\Documents and Settings\{USERNAME}\Documentum\ucf\{MACHINENAME}\shared\config\ucf.client.config.xml) and then check UCF logs. Also check Webtop app server logs. But to my surprise I did not find the config files genrated in the said location under Users/${user_name}/Docuemntum/ucf or Users/${user_name}/Docuemntum/ucf-java.
Also the user has admin rights on his system.
Please suggest something....Its urgent..
Thanks in advance.
