Problem with CallServer
lazybee26
I'm making a callserver call (GET) that returns the following, back to the DCT. I've attached the DCT. The callserver successfully updates the item, when I start a new unnamed DCT. However, it throws "Object doesn't support this property or method" error while saving it. I'm able to enter a file name to save the DCR, but when I click "ok" on that dialog box, I get the error mentioned.
When I debugged, I found that, if I comment out the "setValue" line, it doesn't give any error and saves fine.
Any ideas ?
<html><head>
<SCRIPT LANGUAGE="JavaScript">
var sequence="Failed to get ID";
sequence=1066;//assign next id from the query
function setID (item_name, id){
var scriptFrame = parent.getScriptFrame();
var id_item=scriptFrame.IWDatacapture.getItem("/DestinationGuide/" + item_name);
id_item.setValue(id);
}//SetID
setID ("ID", sequence);
</SCRIPT>
</head><body></body></html>
jbonifaci
I don't think it likes you changing sequence from a string to an int. Make the following change and let me know if it works ok:
sequence=
1066
~Jeff
lazybee26
Great Catch man !!!! It worked !! U guys are so good man !!
Thanks
La Z
