ECM Solution MediaBin connection limitation
Bill Klish
TeamSite 6.1
Solaris 2.8
MediaBin 4.5
I am not sure if this should go into the MediaBin forum or not, but here goes.
I am trying to get the ECM solution up and running, but have a network issue that I need to overcome. The TeamSite server is located on the corporate intranet with no outbound tcp/ip traffic allowed. The MediaBin server is hosted at by a third party ASP. In order to get to the MediaBin server we need to use an HTTP or HTTPS proxy server. How/Where do I configure that?
I opened up the sample_connector_src and went into the src/com/interwoven/sample/connector/teamsite/mediabin directory and opened up the Connector.java file. It looks like I need to be able to somehow enable the MediaBinServerLocator to route the requests through a proxy, but I don't see how that is possible.
Any ideas?
Bill Klish
I think I solved the issue, but I am still waiting to get access to our media bin server so I can test my theory. This should involve nothing more than specifying the proxy settings using Java properties, but it would be good to add a possible setting in the connector.xml configuration file that dynamically reads this in.
