TS Servlet Engine requiring manual invocation
fiquebem
Environment: TS 6.5 on Solaris2.9
After running /etc/init.d/iw.server start, /usr/iw-home/local/logs/iwui/servletd.log shows:
Using CATALINA_BASE: /usr/iw-home/servletd
Using CATALINA_HOME: /usr/iw-home/servletd
Using CATALINA_TMPDIR: /usr/iw-home/servletd/temp
Using JAVA_HOME: /usr/iw-home/tools/java
Using CLASSPATH: /usr/iw-home/tools/java/lib/tools.jar:/usr/iw-home/tools/java/lib/tools.jar:/usr/iw-home/cssdk/cssdkjni.jar:/usr/iw-home/cssdk/cssdkiface.jar:/usr/iw-home/servletd/bin/bootstrap.jar:/usr/iw-home/servletd/bin/commons-logging-api.jar
Error occurred during initialization of VM
java.lang.Error: Properties init: Could not determine current working directory.
Nothing is listening on port 8080. I get farther if I login as root and run the following from /usr/iw-home/local/logs/iwui:
/bin/su iwui -c LANG=C LC_ALL=C; export LANG LC_ALL; nohup /usr/iw-home/servletd/bin/servletd start 1>>/usr/iw-home/local/logs/iwui/servletd.log 2>&1
Then I get the following in servletd.log:
Aug 17, 2005 5:30:05 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Aug 17, 2005 5:30:05 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1548 ms
Aug 17, 2005 5:30:05 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Aug 17, 2005 5:30:05 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.0.27
Aug 17, 2005 5:30:05 PM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
2005-08-17 17:30:16,855 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="fr" it referenced was not found
2005-08-17 17:30:16,860 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="de" it referenced was not found
2005-08-17 17:30:16,860 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="ja" it referenced was not found
2005-08-17 17:30:16,861 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="ko" it referenced was not found
2005-08-17 17:30:16,861 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="zh" it referenced was not found
2005-08-17 17:30:16,861 [main] WARN com.interwoven.ui.base.config.XMLMerger () - iwov-delete tag found but the element language id="zh_tw" it referenced was not found
Aug 17, 2005 5:30:20 PM org.apache.catalina.core.StandardHost getDeployer
INFO: Create Host deployer for direct deployment ( non-jmx )
Aug 17, 2005 5:30:20 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Aug 17, 2005 5:30:20 PM org.apache.jk.common.ChannelSocket init
INFO: JK2: ajp13 listening on /0.0.0.0:8009
Aug 17, 2005 5:30:20 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=1/39 config=/usr/iw-home/servletd/conf/jk2.properties
Aug 17, 2005 5:30:21 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 15443 ms
Now something is listening on port 8080, and the Web Daemon was eventually able to talk to the Interwoven Servlet Engine (after more than 15 seconds for sure).
But I don't see a "servletd" process as it appears on our old TS 6.1 box:
iwui 1657 1 0 Aug 16 ? 616:21 /usr/iw-home/servletd/bin/servletd -server -Xbatch -Xms64m -Xmx512m -Djava.libr
Should I be seeing that on TS 6.5 too?
What should I do to get rid of those foreign language-related warnings? I have the following files in /usr/iw-home/servletd/temp:
applicationconfig.rules51423.merged injection_configs51432.merged uiconfig.rules51431.merged
applications51440.merged openapi51429.merged uiconfigs14958.merged
authconfigs51434.merged portal.rules51426.merged uiconfigs44839.merged
authorizationconfig.rules51421.merged portalconfigs51437.merged uiconfigs51436.merged
command.rules51424.merged reportingconfig.rules51427.merged wizardconfig.rules51428.merged
commandgroups.rules51430.merged reportingconfigs51438.merged workflowconfig.rules51425.merged
commands51433.merged searchconfig.rules51419.merged workflowconfigs51439.merged
cssdk_factory51422.merged searchconfigs48921.merged
injection_config.rules51420.merged searchconfigs51435.merged
injection_configs51432.merged seems to have the language elements that the Servlet Engine was complaining about.
Should I stop TS and trash everything in /usr/iw-home/servletd/temp?
More importantly, what's the remedy for that nasty problem: "Error occurred during initialization of VM / java.lang.Error: Properties init: Could not determine current working directory"?
The current working directory just before iwuiboot invokes servletd is /usr/iw-home/local/logs/iwui. The iwui user owns this directory and has full access to it. It also has read/execute access to the following items:
Any hints?
Many thanks,
S.
There are no comments yet
