Hoping someone here can help - or point me in the right direction....
We're finally getting around to trying out the deployment stuff I've been working on for the last couple of weeks - and, well, it ain't working ;-)
EnvironmentDD 6.0.2 on Windows 2003 EE
Sybase (not SqlAnywhere) on Linux
ProblemDAS: [Thu Aug 18 10:38:11 MDT 2005] Begin executing package_file_list
DAS: Area VPath:/default/main/bigticket/WORKAREA/bigticket_wa
DAS: Setting up TDbSchemaAgent.
DAS: Performing dbcheck for Sybase ASA
DAS: Connecting to a SQLAnyWhere 7.x server using jConnect....
DAS: url : jdbc:sybase:Tds:ip-address
ort/dev1_bt
DAS: login : userid
DAS: login timeout=3
DAS: Connecting to the database...
DAS: Try connecting using jdbc:sybase:Tds:ip-address
ort/dev1_bt...
DAS:
Connected to jdbc:sybase:Tds:ip-address
ort/dev1_bt
DAS: Driver jConnect (TM) for JDBC (TM)
DAS: Version jConnect (TM) for JDBC(TM)/5.5(Build 25020)/P/JDK12/Tue Jun 19 3:13:19 2001
DAS:
DAS: *******************************************************
DAS: SQLException occured in TSybaseASADbCheck
oDbCheck
DAS: Exception Message: SYSINFO not found. Specify owner.objectname or use sp_help to check whether the object exists
(sp_help may produce lots of output).
DAS: Vendor Error Code: 208
DAS: SQL state: 42000
DAS: *******************************************************Apparently we need to use a different version of
jConnect and to that end, we've brought over a
jconn3.jar file and put it into
odhome/drivers/ but that doesn't seem to have made any difference.
Can someone tell me if/how we can put this version of the driver into place so it gets used instead of the one that thinks we're talking to a SqlAnywhere DB ?
--fish
http://www.quotient-inc.com
