Re: Error from Process Engine Installation
Hello All,
I got error during the process installation on my documentum 6.6. I wonder if you could shed a light on what errors meant?
The error were as following:
16:33:06,359 WARN [Thread-1] com.documentum.install.pe.common.beans.wizard.action.DiWAPeInitialize - init-param tags found in Method Server webapp:
<init-param> <param-name>docbase_install_owner_name</param-name> <param-value>user</param-value> </init-param>
<init-param> <param-name>docbase-documentum</param-name> <param-value>documentum</param-value> </init-param>
16:35:37,750 ERROR [Thread-7] com.documentum.install.pe.common.beans.product.action.DiPAPeProcessDars - Failed to extract dars.jar; Unable to create target file: C:\Documentum\product\6.6\install\DARsInternal\BPM.dar
com.documentum.install.shared.common.error.DiException: Unable to create target file: C:\Documentum\product\6.6\install\DARsInternal\BPM.dar
at com.documentum.install.shared.common.services.jar.DiJarUtils.getFileOutputStream(DiJarUtils.java:189)
at com.documentum.install.shared.common.services.jar.DiJarUtils.extractWithoutIsx(DiJarUtils.java:758)
at com.documentum.install.pe.common.beans.product.action.DiPAPeProcessDars.extractDars(DiPAPeProcessDars.java:153)
at com.documentum.install.pe.common.beans.product.action.DiPAPeProcessDars.install(DiPAPeProcessDars.java:49)
at com.installshield.product.service.product.PureJavaProductServiceImpl.installProductAction(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.getResultForProductAction(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitComponent(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitInstallableComponents(Unknown Source)
at com.installshield.product.service.product.InstallableObjectVisitor.visitProductBeans(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(Unknown Source)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(Unknown Source)
at com.installshield.wizard.service.AsynchronousOperation.run(Unknown Source)
at java.lang.Thread.run(Thread.java:619)
------- BEGIN "Global Context" output -------
[COMMON]
UI_MODE=AWT
IS_SUITE_INSTALLATION=TRUE
BOF_GLOBAL_REGISTRY_DFC_PANEL_IS_ENABLED=FALSE
ECI_SERVICES_ASK=FALSE
PIA_OPTION_HIDE=FALSE
DCTM_PROGRAM_DIR=C:\Program Files\Documentum
DCTM_LOCATION=C:\Program Files\Documentum
SETUP_FILES_FOLDER=C:\Program Files\Documentum\setup
DCTM_USER_DIR=C:\Documentum
WINDOWS_DIRECTORY=C:\WINDOWS
WINDOWS_ROOT_DIRECTORY=C:
DEFAULT_BROWSER=IEXPLORE
VERSION_IEXPLORER=8.0.6001.18702
VERSION_NAVIGATOR=
COMPUTER_NAME=T-327DA3A212654
USER_ACCOUNT=user_2
USER_DOMAIN=T-327DA3A212654
USER_IS_ADMIN=TRUE
OPERATING_SYSTEM=7
SERVICE_PACK=3
SCREEN_RES_X=1280
SCREEN_RES_Y=800
USER_PROGRAMS_FOLDER=C:\WINDOWS\system32\config\systemprofile\Start Menu\Programs
USER_GROUP=
TEMP_DIR=C:\DOCUME~1\user_2\LOCALS~1\Temp
SUPPRESS=TRUE
GROUP_NAME=MethodServer
DFC_FOLDER=C:\Program Files\Documentum\shared
HELP_FOLDER=C:\Program Files\Documentum\Help
CONFIG_FOLDER=C:\Documentum\config
BUNDLED_JAVA_HOME=C:\Program Files\Documentum\java\1.6.0_17
JARS_TO_REGISTER_IN_DCTM_JAR=Shared/dfc.jar Shared/jsafeFIPS.jar Shared/certjFIPS.jar Shared/log4j.jar Shared/All-MB.jar Shared/bpmutil.jar Shared/ci.jar Shared/subscription.jar Shared/workflow.jar Shared/xforms.jar Shared/dam_services.jar Shared/tar.jar Shared/xtrim-api.jar Shared/messageService.jar Shared/messageArchive.jar Shared/xtrim-server.jar Shared/DmcRecords.jar Shared/configservice-api.jar Shared/configservice-impl.jar
[JRE_ENVIRONMENT]
java.version=1.6.0_17
java.vendor=Sun Microsystems Inc.
java.vendor.url=http://java.sun.com/
java.home=C:\DOCUME~1\user_2\LOCALS~1\Temp\LRE61.tmp\jre
java.vm.version=14.3-b01
java.vm.vendor=Sun Microsystems Inc.
java.vm.name=Java HotSpot(TM) Client VM
java.class.path=;dars.jar;appServer.jar;serviceWrapperManager.jar;peWinSuiteSetup.jar;peSetup.jar;dfcWinSetup.jar;peWinSuiteSetup.jar;
java.ext.dirs=C:\DOCUME~1\user_2\LOCALS~1\Temp\LRE61.tmp\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
os.name=Windows XP
os.arch=x86
os.version=5.1
user.name=user_2
user.home=C:\Documents and Settings\user_2
user.dir=C:\dung\Documentum\taskspace\process_engine
[NATIVE_ENVIRONMENT]
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\user_2\Application Data
asl.log=Destination=file
CLASSPATH=C:\Program Files\Documentum\dctm.jar;C:\Documentum\config;C:\Documentum\product\6.6\dctm-server.jar;.;C:\Program Files\Java\jre1.5.0_12\lib\ext\QTJava.zip
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=T-327DA3A212654
ComSpec=C:\WINDOWS\system32\cmd.exe
DM_HOME=C:\Documentum\product\6.6
DOCUMENTUM=C:\Documentum
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\user_2
JAVA_HOME=C:\DOCUME~1\user_2\LOCALS~1\Temp\LRE61.tmp
LOGONSERVER=\\T-327DA3A212654
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\Program Files\Documentum\Shared;C:\Documentum\product\6.6\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;C:\Program Files\IBM\SPSS\Modeler\14\ext\lib\spss.TMWBClient;C:\Program Files\IBM\SPSS\Modeler\14\bin;C:\CFusionMX7\verity\k2\_nti40\bin;C:\Program Files\Insightful\splus80;%ANT_HOME%\bin;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\SAS\Shared Files\Formats;C:\Program Files\QuickTime\QTSystem;c:\Documentum\mssql\90\Tools\binn;c:\Documentum\mssql\90\Tools\binn\;C:\DOCUME~4\fulltext\lucene;C:\Program Files\Java\jre6\bin\javaw.exe;C:\Python27
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 104 Stepping 2, AuthenticAMD
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=6802
QTJAVA=C:\Program Files\Java\jre1.5.0_12\lib\ext\QTJava.zip
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\user_2\LOCALS~1\Temp
TMP=C:\DOCUME~1\user_2\LOCALS~1\Temp
USERDOMAIN=T-327DA3A212654
USERNAME=user_2
USERPROFILE=C:\Documents and Settings\user_2
VERITY_CFG=C:\CFusionMX7\verity\k2\common\verity.cfg
windir=C:\WINDOWS
__COMPAT_LAYER=EnableNXShowUI
[DFC_BUILD]
YEAR=2010
[DFC]
DISPLAY_MINOR_VERSION=6.6
DISPLAY_MAINTENANCE_VERSION=6.6.0
DISPLAY_FULL_VERSION=6.6.0 (Build 39)
VERSION=6.6.0.39
DCTM_CHECKOUT_DIR=C:\Documentum\Checkout
DCTM_EXPORT_DIR=C:\Documentum\Export
DJCB_PATH=
DJCB_CLASS_PATH=
DJCB_VM_ARGS=
DJCB_JAVA_VM=DLL=C:\Program Files\Documentum\java\1.6.0_17\jre\bin\client\jvm.dll
DOCUMENTATION_FEATURE=FALSE
APPTOKEN_DIR=C:\Documentum\apptoken
DFC_APPTOKEN_GENERIC_DIR=C:/Documentum/apptoken
DFC_DATA_DIR=C:\Documentum
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 31 Developer Tools
- 123 Exstream
- 1 XM Fax
