Anyone know exactly which Process engine build to use for CS 7.1 with D2?
If there are Accepted Answers, those will be shown by default. You can switch to 'All Replies' by selecting the tab below.
in the environment requirements pdf there's a table with the interoperability versions of different products (you can check it in 7.2 environment and requirements guide). If I'm not mistaken is the pe bundled with xCP 2.1 (latest patch) but check it in the pdf just in case...
