We have an application that consists of multiple work spaces (were each one identifies a different department, lets say). All work spaces make use of the same object type and property page for documents. We now have a use case where on some of the work spaces (departments) a couple of the attributes are required, but they are not required in the other work spaces (departments).
Is there a way to control whether the attributes are required based on the current user's work space context?
In D2-Config, on the attribute definition you can specify a Required Condition, but that is exclusively based on using the available attributes. I was thinking of using the Advanced View Editor and wondering if there is way to determine the current work space context using that. What functions/methods are available for use in the editor (is there a list documented somewhere)?
