Problem while using 2 VFE
amol82
hi
I am using two different VFE config files on a single DCT.
VFE gives an error regarding registration key when i try to switch between two VFE
Can this be be done.
thanks
Amol
Nicholas
Can you write a bit more about your configuration?
amol82
hi
My configuration is that I am using Teamsite 6.1 on solaris server . On a single DCT i am having two VFE which we have customized according to our needs like one is with tables and another is without table .
when i click on first it works fine and when i click on second it also loads smoothly but if i go back to the first it gives an error msg.
I have attached a screen shot of the error.
Thanks
Amol
amol82
The version of ewebeditpro is 3.1.0.11
Nicholas
I am not sure exact reason behind this issue. did you checked on your server, ewebeditprolicensekey.txt available?
Nicholas
You can also find more information about error message in VFE guide in "Appendix B: Error Messages"
Hope this will help
Thanks Nicholas
