Hi ,Using TS 6.5 SP1 Win 2003I am using VFE in my DCTs .I have to embed some content from Microsoft Word document .What I do is click on 'Word' icon on VFE toolbar . Word opens up . Enter some bulleted points on Word editor . Close the word editor .....the text starts appearing in VFE . When we generate the page .....the content is not well formated as it was on Word .It is very much frustrating for the content authors to struggle with the formattting issue of their content entered through VFE .Also if i use Roman Bullets in Word , then copy it into VFE they are converted into 1,2,3 ......Could anyone let me know ..what is the best way to tackel this problem .Pls help Rohit Pathak
Hi,the rubbish that Word creates is a serious problem for any tool that tries to format it. Including the VFE.I think the best approach would be:- set VFE to clean as much of the Word-stuff- have a look at the html that comes out of it and then...- create/add/modify your css in order to make it work the way you want itRemember however that you will NEVER be able to support all Word-markup-features in your html. You should instruct your users to only use a limitted sub-set of the Word-formatting.And if they really want all word-options you should dump teamsite and buy a frontpage license for them. :-)Cheers, Ronald
