iwserver mount point not determined
marcussteiner
Hi all,
I've got this strange problem on TS 6.1 on Solaris 8. When I run:
(-d:/etc/init.d)% ./iw.server start
This is the output in iwserver.log.
any ideas?
cheers
m
iw.server: ---------- STARTING: Fri Jun 23 17:48:41 MEST 2006
iwetcboot: Running iwstart /ecmd/ecm/iw-store in /ecmd/ecm/iw-home
iwstart: The events log file is /iwenv/log/iwevents.log
iwstart: resetting wfs queue state ... done
iwstart: Resetting aborted state of kernel queue
iwstart: checking for standard services
iwstart: nfsd running
iwstart: mountd running
iwstart: Starting iwprocdstart script (log file: /var/adm/iwprocessd.log)... DONE
iwstart: Spawning iwserver.sol (trace file: /iwenv/log/iwtrace.log)...
iwstart: Waiting up to 60 seconds for iwserver to come up... READY
iwmount: /.iwmnt/default has previously been mounted. Umounting it...
nfs umount: /.iwmnt/default: is busy
iwmount: /.iwmnt/default has failed to umount
iwmount: Mounting /iwmnt/default...
mount: mount point cannot be determined
iwmount: Mounting /.iwmnt/default...
umount: warning: /iwmnt/default not in mnttab
umount: /iwmnt/default not mounted
iwmount: Waiting for iwserver to be ready...
Migrateduser
Yikes -- you might want to call support on this one. I've had similar issues more than a few times in the past and it seems that the root cause is always something so obscure.
marcussteiner
LOL. nice one :-)) that makes my day....
i'll give them a call.
nipper
Just for kicks, do a df -k
I have seen a process running in /iwmnt so it would nout unmount
You can try
umount -f /iwmnt
umount -f /.iwmnt
(do not know if you need both)
Andy
marcussteiner
This certainly does not look good:
(-d:/)% umount -f /iwmnt
umount: warning: /iwmnt not in mnttab
umount: /iwmnt not mounted
(-d:/)% umount -f /.iwmnt
umount: warning: /.iwmnt not in mnttab
umount: /.iwmnt not mounted
/dev/md/dsk/d34 1018382 80153 877127 9% /var/opt/apache
/dev/md/dsk/d36 1542412 1003661 523327 66% /opt/oracle/product/8.1.7
/view 1986439 1663920 262926 87% /view
ecars6:/iwserver/default
18418612 17064878 1169548 94% /.iwmnt/default
df: cannot statvfs /my_mnt: Stale NFS file handle
/net/ecarsq1/rqpp/vobs/WSC_ECA.vbs
20643785 16439861 3997487 81% /rqpp/projects/WSC_ECA
/net/ecarsq1/ccdata1/vobs/WSC_TEST.vbs
99382619 80409081 17979712 82% /rqpp/projects/WSC_TEST
thanks for the help
nipper
Probably need to restart the box. Any chance of that ?
I see you have ClearCase on this box. How long have both been on the server ?
One more thing to try:
/usr/ucb/ps -wuax | grep iwmnt
That runs the old UCB version of PS which has a wide option and will show if the process is in a directory. There is a process running in iwmnt preventing it from umounting.
I thought there should be an entry in the mntab file for iwmnt so that you can use umount.
You may want to view the /etc/init.d/iwserver file and copy the umount command they use but add the -f (force) flag.
Andy
marcussteiner
I'll try to restart the box on monday and will torture the sys-admins with that.
(-d:/)% /usr/ucb/ps -wuax | grep iwmnt
root 14960 0.1 0.1 1000 728 pts/5 S 18:43:42 0:00 grep iwmnt
(-d:/)%
I will also check the clearcase stuff. thanks
nipper
I do not have my Soliris server available, run this for me:
grep umount /etc/init.d/iw.server
marcussteiner
(-d:/)% grep umount /etc/init.d/iw.server
(-d:/)%
nipper
looks like that is in iwmount
do a grep umount on any file named iwmount in either /etc/init.d or $iwhome/private/bin
Screenshot.doc
marcussteiner
i'm currently rebooting -play server- and will see what happens then
how would i do this?
marcussteiner
i know i should not do this but the fu/%/%/)/)/(&%%§%§%$§ing box is back.
and ts is running.
thanks for the help
nipper
So you are saying I fixed it. Cool
marcussteiner
you are teeee man...
off now weekend in old europe
