Deploy to same table twice in the same deploy give problems
williamIV
I have two different parts of my dcr that are being pushed to the same table in the database. In my data config I have two groups corresponding to the two parts of the dcr and with different group names but the same table.
When I run the data deploy it only uses the definition from the first group.
my data config is attached the duplicated segments are associatedContent and abstractImage.
Migrateduser
I can't see your attachment. You can not have multiple definitions (mappings) for the same table.
I'm curious to see what you're trying to do. can you post your files again?
Mariam
