Hi All, I have got problem with my prepared statement. I need to update a value in to DB. I hardcoded those values and it worked. But when I am trying to do the same using prepared statement it is not updating the value in database and not even throwing an error.Pls find the code:- my $stmt = "update table set level = '?' where record_path like '%18032%'"; my $sth = $dbh->prepare($stmt) or die "Can not prepare SQL statement: $DBI::errorstr\n";$sth->execute('hello');$dbh->disconnect or warn "Disconnection failed: $DBI::errstr\n"; Here the level value should be hello after updating.Thanks in advance........thanks,chkri
