Running into problems with saving DCR's
awizardly
TeamSite 6.1sp2 Solaris
We are running into problems saving dcr's that happen to have certain keywords in the text of a text area field. These DCR's have been saved several times before, and submitted. This just started cropping up.
They look suspiciously like SQL keywords. Does anyone know if there is any special parseing in DCT's for SQL handling?
What we are seeing is something like
When it breaks the text looks like this
.... select ..... Saves correctly
.... where ..... Saves correctly
.... where ..... select ..... where ........ Saves correctly
.... select .... where ...... where ........ Fails and Browser Hangs
We've found some stack traces in the localhost_log on of the server, and we are seeing a stack trace that basically indicates that the dcr vpath isn't getting passed in and the jsp throws a null pointer exception.
Other DCR's using the same datacapture.cfg are working fine, in fact these dcr's worked fine for quite some time and recently stopped being saveable.
I'll be putting in a support request but I was hoping someone has seen this before.
nipper
Do you have any formapi running ? Can you disable that & see if the error still happens ? Otherwise I think your system is haunted. Maybe Greg Zevin worked on it.
