Problem while logging into OD 6.1.0
curious_sam
while trying to logging into user interface of OD 6.1.0 I am getting the following error(even for the bootstrap user);
ENG: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 ***ERROR - SQLException: User not found: SA
java.sql.SQLException: User not found: SA
at org.hsql.Trace.getError(Trace.java:124)
at org.hsql.Trace.getError(Trace.java:115)
at org.hsql.Trace.error(Trace.java:130)
at org.hsql.Access.get(Access.java:109)
at org.hsql.Access.getUser(Access.java:88)
at org.hsql.Database.connect(Database.java:60)
at org.hsql.jdbcConnection.openStandalone(jdbcConnection.java:662)
at org.hsql.jdbcConnection.(jdbcConnection.java:524)
at org.hsql.jdbcDriver.connect(jdbcDriver.java:78)
at java.sql.DriverManager.getConnection(DriverManager.java:512)
at java.sql.DriverManager.getConnection(DriverManager.java:171)
at com.interwoven.deploy.engine.TMacroDeployInitiator.compactHsql(TMacroDeployInitiator.java:3050)
at com.interwoven.deploy.engine.TMacroDeployInitiator.initScheduler(TMacroDeployInitiator.java:397)
at com.interwoven.deploy.engine.TMacroDeployInitiator.(TMacroDeployInitiator.java:125)
at com.interwoven.deploy.engine.TMacroDeployInitiator.(TMacroDeployInitiator.java:156)
at com.interwoven.deploy.engine.TDeploySvrEngine.(TDeploySvrEngine.java:1062)
at com.interwoven.deploy.engine.TDeploySvrEngine.create(TDeploySvrEngine.java:285)
at com.interwoven.deploy.cdmain.IWCDMain.main(IWCDMain.java:1707)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at com.interwoven.deploy.cdmain.IWCDBoot.run(IWCDBoot.java:255)
at java.lang.Thread.run(Thread.java:534)
ENG: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 ***ERROR - Compacting HSQL script file
at com.interwoven.deploy.engine.TMacroDeployInitiator.initScheduler(TMacroDeployInitiator.java:432)
ENG: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 ***ERROR - Failed to initialize scheduler
SVR: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 ***ERROR - OpenDeploy engine component encountered error.
SVR: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 ERROR DETAILS:
ERROR: Failed to initialize scheduler
SVR: 2007-06-26 15:04:34 GMT+05:30 GMT+05:30 Bring up of OpenDeploy server FAILED.
Can anyone throw some light on it?
nipper
Yes, this is a known issue. You need to rebuild the openJMS DB, (by deleting the old one). Check this
thread
Andy
