Hello friends,In my DCT, I have a textarea and a couple of radio box(with values Bulleted List/Numbered List).Depending on the selection of the radio box, in the final page, a bulleted list or numbered list is created from the data entered in the textarea.Attached herewith is the code for Split function used in the TPL for displaying the list.Here I am facing a problem.When the page is created for the first time, the list gets displayed perfectly(i.e. there is no empty bulleted/Numbered line).No when I come to the edit mode, if i hit "enter" after a particular value, the page gets displayed perfectly.But When i hit "enter" before a particular value, a blank bulleted\numbered line is created.Can anyone point out what modification is needed in my attached code?TIAMav
I tried that, but no use....
Hi Boris,can we chat sometime online discussing the issue?Finding it a bit difficult to explain since the problem is not exactly with the codes...
Thanks a lot. Do you have yahoo messenger or gtalk id?
Also do you think that while check for blankness both emptiness of the string as well as null value should be checked for?
