The information in this article applies to product: e-Work 6.x
Issue
- A formula with nested conditional operations is built using the Integration Wizard (IW). When the formula is reopened in the IW, the IW modifies it, and the message The formula cannot be parsed may be generated. The formula must be rebuilt.
Resolution
- This is a known issue. Do not use the Integration Wizard to open formulas that contain nested conditional operations. Use the formula editor instead.
