The information in this article applies to:
Product: Metastorm BPM
Version: 6.6.4.6
Issue
If Oracle is used as the database, the following error message is written to the Windows application event log after Metastorm BPM 6.6.4 hot fix 6 (6.6.4.6) is installed:
Event Type: Error
Event Source: e-Work Engine
Event Category: eEventManager
Event ID: 1
Date: 6/27/2007
Time: 1:27:53 PM
User: N/A
Computer: S1FFA55
Description:
Database problem while doing: Opening eWait table. m\_nRetCode: -1, m\_strError: 'ORA-00904: "ESEQUENCENO": invalid identifier ', m\_strStateNativeOrigin: 'State:S0022,Native:904,Origin:\[Oracle\]\[ODBC\]\[Ora\] '
Resolution
Run the SQL scripts for Oracle in the following order.
- eWorkTypes.sql
- eWorkPackage.sql
- eWorkProcedures.sql
Use the @ command to run the script. For example, @C:\\Temp\\eWorkTypes.sql
The scripts are located here: :\\Program Files\\Metastorm e-Work\\Engine\\Database\\ORACLE scripts
Note that the Release Notes for version 6.6.4.6 incorrectly state that the Oracle scripts do not need to be run.
