TS 6.7.1 Installation problem
System
I am getting the following msg during installation which is not part of the standard msg:
"The following port(s) are busy: 80
Click previous to change the port number or next to continue."
After changing the webd port to 88, the installation is successful. But the login page is not founhd when localhost:88/iw-cc URL is acessed.
What is the cause of the msg?
any help is appreciated.
Migrateduser
To clarify, Port 80 was not used but the post is busy msg is appearing.
cute_guy
The port might be used by your IIS (or webserver), when you give continue the 80 port will be used by TeamSite and later when you run postreboot script the webserver will be configured to run in port 81
nipper
what do you see if you point a browser to
http://server:80/
