Has anyone had problems with multiclips when using SharePoint in version 9?
I have a multiclip that's set up with MS SharePoint as the DMS. There is no problem when adding new documents or checking out existing ones. I can check out an existing document and make changes to it, but when I check it back in, the changes that I made are lost. I've tested out a number of scenarios (checking in w/comments, checking in w/o comments, checking in but having the document remained check out), but the check-in process has never worked successfully.
(My environment is set up with SSO and has SR3 applied.)
