I am running ProVision 6.23 (I think - can't tell for sure because it won't start at the moment!). When I try to start it it says
"Provision does not have write access to C:\PVDATA\v623\connections.pvr.
1. This file may be in use by another application. Please exit ... OR
2. You do not have permission to access this file..."
Screen capture attached.
I can't tell why either of these would be the case. Only solution seems to be to reboot the PC. This is VERY annoying!
Most of the time it works fine; often this problem occurs if I put my PC to sleep and then wake it up (not whilst PV is running!)
Ideas?
Regards, Peter Ghys
Melbourne, Australia
