OTDS Configuration Issue - Already connected issue configuring Appworks Gateway
Hi
I am trying to configure Appworks against OTDS using 'Configure OTDS' but I get an error that OTDS setup did not complete successfully:
This is the error in the gateway-otag.log file:
2017-11-20 10:51:25,3822017-11-20T10:51:25,382 [http-nio-8443-exec-14] ERROR service.impl.SetupBeanImpl - We were unable to use the provided OTDS configuration details, Already connected
javax.ws.rs.ProcessingException: Already connected
I initially created an existing setup with Appworks and successfully set this up against an External OTDS. However, I need to do a re-install so I dropped the db and connected to the DB successfully but for the OTDS setup it still thinks there is a connection setup. Where is this stored? I deleted the information in OTDS for Resources and Partition created from the previous install. But it looks like this is stored locally somewhere. What do I need to clean up to try and re-created the information in the external OTDS.
I am using Appworks 16.3 against OTDS 16.
Hope you can help.
Thanks
Chas
Hi Simon
Thanks for the reply, I believe I did delete the file but I am not sure if I restarted tomcat. This has DB information and not OTDS related information. So the DB connection was connected successfully but not OTDS. Do I delete this file again and restart Tomcat. If I do this, will I not lose the DB information?
Cheers
Chas0 -
Hi Chas
The OTDS information is held in the DB in two tables , the setting table and one other
On startup the Gateway looks for the opentext.properties file and then attempts to connect to the DB defined therein and then it gets from the DB the OTDS it needs to connect to
If the opentext.properties file doesn't exist or is unreadable then the Gateway will show the setup page
If you did delete the file you will certainly need to restart Tomcat
S
0 -
Hi Simon
So I deleted the DB again and removed the opentext.properties and restarted the tomcat. I then was able to connect successfully to the new DB which created new tables. However, the OTDS it failed.
gateway-otag.log:
2017-11-22 16:56:04,8792017-11-22T16:56:04,879 [Thread-9] INFO services.impl.SettingServiceImpl - Setting otag.smtp.host is not usable. Setting default of localhost
2017-11-22 16:56:04,8842017-11-22T16:56:04,884 [Thread-9] INFO services.impl.SettingServiceImpl - Setting otag.smtp.from is not usable. Setting default of noreply@example.com
2017-11-22 16:56:04,8892017-11-22T16:56:04,889 [Thread-9] INFO services.impl.SettingServiceImpl - Setting otds.auth.disable.sso.addresses is not usable. Setting default of
2017-11-22 16:56:05,1922017-11-22T16:56:05,192 [http-nio-8443-exec-10] INFO services.impl.SettingServiceImpl - Setting otag.url is not usable. Setting default of https://GBLDNSRV9DW4144.ANYACCESS.NET:8443
2017-11-22 16:56:05,4012017-11-22T16:56:05,401 [http-nio-8443-exec-10] ERROR service.impl.SetupBeanImpl - We were unable to use the provided OTDS configuration details, Already connected
at org.glassfish.jersey.client.ClientRuntime.invoke(ClientRuntime.java:233) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:655) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.JerseyInvocation$1.call(JerseyInvocation.java:652) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:228) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:424) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.client.JerseyInvocation.invoke(JerseyInvocation.java:652) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.JerseyInvocation$Builder.method(JerseyInvocation.java:412) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.JerseyInvocation$Builder.post(JerseyInvocation.java:321) ~[jersey-client-2.8.jar:?]
at com.opentext.otag.auth.otds.OtdsClientImpl$OtdsRestApiWrapper.lambda$post$0(OtdsClientImpl.java:382) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsClientImpl$OtdsRestApiWrapper.doRequest(OtdsClientImpl.java:421) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsClientImpl$OtdsRestApiWrapper.post(OtdsClientImpl.java:381) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsClientImpl.post(OtdsClientImpl.java:292) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsClientImpl.authenticateWithPassword(OtdsClientImpl.java:73) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsClientImpl.clientForUser(OtdsClientImpl.java:242) ~[classes/:?]
at com.opentext.otag.auth.otds.OtdsInstaller.connectToOtds(OtdsInstaller.java:233) ~[classes/:?]
at com.opentext.otag.api.service.impl.SetupBeanImpl.connectToExistingOtds(SetupBeanImpl.java:431) ~[classes/:?]
at com.opentext.otag.api.service.impl.SetupBeanImpl.setupOtds(SetupBeanImpl.java:403) ~[classes/:?]
at com.opentext.otag.api.service.impl.SetupBeanImpl.stageTwoOtdsConfig(SetupBeanImpl.java:174) ~[classes/:?]
at com.opentext.otag.api.endpoints.admin.SetupResource.lambda$doStageTwoOtdsConfig$1(SetupResource.java:77) ~[classes/:?]
at com.opentext.otag.api.util.RestHelper.doRun(RestHelper.java:35) [classes/:?]
at com.opentext.otag.api.endpoints.admin.SetupResource.doStageTwoOtdsConfig(SetupResource.java:76) [classes/:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_144]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_144]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_144]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:1.8.0_144]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:151) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:171) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:152) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:104) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:387) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:331) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:103) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:269) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:297) [jersey-common-2.8.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:252) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1023) [jersey-server-2.8.jar:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:372) [jersey-container-servlet-core-2.8.jar:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:382) [jersey-container-servlet-core-2.8.jar:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:345) [jersey-container-servlet-core-2.8.jar:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:220) [jersey-container-servlet-core-2.8.jar:?]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292) [catalina.jar:8.0.38]
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207) [catalina.jar:8.0.38]
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.0.38]
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240) [catalina.jar:8.0.38]
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:720) [catalina.jar:8.0.38]
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:466) [catalina.jar:8.0.38]
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:391) [catalina.jar:8.0.38]
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:318) [catalina.jar:8.0.38]
at com.opentext.otag.servlet.AWGGatewayFilter.doFilter(AWGGatewayFilter.java:117) [classes/:?]
at com.opentext.otag.auth.OAuthFilter.doFilter(OAuthFilter.java:66) [classes/:?]
at com.opentext.otag.servlet.RemoteAddressFilter.doFilter(RemoteAddressFilter.java:103) [classes/:?]
at com.opentext.otag.servlet.AWGTenantFilter.doFilter(AWGTenantFilter.java:60) [classes/:?]
at com.opentext.otag.api.shared.util.AWGPreProcessorFilter.doFilter(AWGPreProcessorFilter.java:26) [otag-api-shared-16.3.0.jar:?]
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212) [catalina.jar:8.0.38]
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106) [catalina.jar:8.0.38]
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502) [catalina.jar:8.0.38]
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141) [catalina.jar:8.0.38]
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) [catalina.jar:8.0.38]
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616) [catalina.jar:8.0.38]
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88) [catalina.jar:8.0.38]
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:528) [catalina.jar:8.0.38]
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1100) [tomcat-coyote.jar:8.0.38]
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:687) [tomcat-coyote.jar:8.0.38]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520) [tomcat-coyote.jar:8.0.38]
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1476) [tomcat-coyote.jar:8.0.38]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_144]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_144]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.0.38]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_144]
Caused by: java.lang.IllegalStateException: Already connected
at sun.net.www.protocol.http.HttpURLConnection.setRequestProperty(Unknown Source) ~[?:1.8.0_144]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.setRequestProperty(Unknown Source) ~[?:1.8.0_144]
at org.glassfish.jersey.client.HttpUrlConnector.setOutboundHeaders(HttpUrlConnector.java:348) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.HttpUrlConnector.access$100(HttpUrlConnector.java:87) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.HttpUrlConnector$3.getOutputStream(HttpUrlConnector.java:311) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.commitStream(CommittingOutputStream.java:200) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.commitStream(CommittingOutputStream.java:194) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.message.internal.CommittingOutputStream.commit(CommittingOutputStream.java:262) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.message.internal.OutboundMessageContext.commitStream(OutboundMessageContext.java:811) ~[jersey-common-2.8.jar:?]
at org.glassfish.jersey.client.ClientRequest.writeEntity(ClientRequest.java:543) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.HttpUrlConnector._apply(HttpUrlConnector.java:315) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.HttpUrlConnector.apply(HttpUrlConnector.java:227) ~[jersey-client-2.8.jar:?]
at org.glassfish.jersey.client.ClientRuntime.invoke(ClientRuntime.java:224) ~[jersey-client-2.8.jar:?]
... 87 more
2017-11-22 16:56:05,4082017-11-22T16:56:05,408 [http-nio-8443-exec-10] ERROR api.util.RestHelper - Internal Error - null
com.opentext.otag.exception.OTAGException: null
at com.opentext.otag.api.service.impl.SetupBeanImpl.stageTwoOtdsConfig(SetupBeanImpl.java:189) ~[classes/:?]
2017-11-22 16:56:06,0422017-11-22T16:56:06,042 [Thread-9] INFO otag.upgrade.UpgradeServiceImpl - Loaded Gateway version based on otag.properties - 16.3.0
2017-11-22 16:56:06,0452017-11-22T16:56:06,045 [Thread-9] INFO otag.upgrade.UpgradeServiceImpl - The database says that the current Gateway version is - 16.3.0, comparing with 16.3.00
- 111 Developer Announcements
- 49 Articles
- 103 General Questions
- 123 IM Services
- 40 OpenText Hackathon
- 32 Developer Tools
- 124 Exstream
- 1 XM Fax
