Separate work flow for categories in a work flow
lucifer
Hi all,
I want to know if i can define a separate workflow for each category in work area?
If yes, can you please explain how to do it?
I am using TS 5.0.2 on windows 2000 server
Migrateduser
Can you define what you mean by "category"?
Dave Smith
Sr. Software Engineer
Nike, Inc.
(503) 671-4238
DavidH.Smith@nike.com
akshathp
I understand that you are looking for a way to limit the access of a Worlflow to a particular section/directory/folder in a particular workare. Correct me if I am wrong.
If this is correct, then yes it is possible. You could specify in the available_templates.ipl and available_template.cfg the folder to which a particular workflow is to be limited.
Hope this helps.
Akshat Pramod Sharma
Interwoven Inc.
lucifer
thanks
I t works...
Migrateduser
Hi Akshat/ Lucifer,
I tried to check for the folder instead of a branch, but didn't work.
e.g. In the available_templates.cfg, I had following setting
<branch_list>
<branch value='default/main/Prod/WORKAREA/Wa1/Category1' include ='yes'/>
<branch value='all' include ='no'/>
</branch_list>
Where Wa1 is the name of my workarea and Category1 is the name of the folder.
Now if I try start a workflow on a file from Category1 folder, it doesn't show any workflows as the regex match fails.
Is it really possible to check the folder names and not just the branch names?
Thanks
-Ashish
Adam Stoller
using the branch directive for anything beyond a branch vpath has generally worked for New Job and Submit, but not for tt_data.
When in doubt as to what is happening, enable debugging in available_templates.ipl so that you can see what information is getting passed into (and out of) the function for determining what workflows are available.
--fish
http://www.quotient-inc.com
