Hello,We have just upgraded our production Teamsite installation from version 6.0.1 to version 6.7.1 (OD 6.0.1) and we now have problems promoting content via OpenDeploy to certain receivers.We've tried adding the fix "teamsite.version: 6.7.1.0" line to our deploy.cfg and restarted but it doesn't make any difference.Here is the log from a failed promotion:ENG: 2007-09-24 11:09:02 BST GMT+01:00 Thread-23 Block max wait time (sec): 1800ENG: 2007-09-24 11:09:02 BST GMT+01:00 Thread-23 Block check interval (sec): 30ENG: 2007-09-24 11:09:03 BST GMT+01:00 Thread-23 Remote side has path registry disabledLIB: 2007-09-24 11:09:03 LOGFILE=[/apps/interwoven/OpenDeployNG/log/src.to_production_webserver26936.DOCROOT.us1531.to.live_webserver_383.log]LIB: 2007-09-24 11:09:03 Locale=[English_UnitedStates.US-ASCII@Binary]LIB: 2007-09-24 11:09:03 ERROR: Failed open session with TeamSiteLIB: 2007-09-24 11:09:03 ERROR: Failed converting area(/default/main/nam/EDITION) to VPATHLIB: 2007-09-24 11:09:03 Interwoven OpenDeploy(6.0.1.0.0 Build 41860 Interwoven 20041018)LIB: 2007-09-24 11:09:03 LIB: Component Version (6.0.1.0.0 Build 41860 Interwoven 20041018)LIB: 2007-09-24 11:09:03 ERROR: Failed open session with TeamSiteLIB: 2007-09-24 11:09:03 ERROR: Failed converting area(/default/main/nam/EDITION) to VPATHLIB: 2007-09-24 11:09:03 Buffer Size (8000)LIB: 2007-09-24 11:09:03 Protocol Version(5.0) OKLIB: 2007-09-24 11:09:03 Connection Id(id=m2)LIB: 2007-09-24 11:09:03 ERROR: Failed open session with TeamSiteLIB: 2007-09-24 11:09:03 ERROR: Failed converting area(/default/main/nam/EDITION) to VPATHLIB: 2007-09-24 11:09:03 Transaction Mode: ONLIB: 2007-09-24 11:09:03 Mode(normal)LIB: 2007-09-24 11:09:03 ERROR: Failed open session with TeamSiteLIB: 2007-09-24 11:09:03 ERROR: Failed converting area(/default/main/nam/EDITION) to VPATHENG: 2007-09-24 11:09:03 BST GMT+01:00 Thread-23 After SETUP, res=-1ENG: 2007-09-24 11:09:03 BST GMT+01:00 Thread-23 exiting setupENG: 2007-09-24 11:09:03 BST GMT+01:00 Thread-23 entering awaiting-cleanupENG: 2007-09-24 11:09:03 BST GMT+01:00 Thread-23 still waiting for 0ENG: 2007-09-24 13:06:41 BST GMT+01:00 Thread-23 exiting awaiting-cleanupENG: 2007-09-24 13:06:41 BST GMT+01:00 Thread-23 entering cleanupENG: 2007-09-24 13:06:41 BST GMT+01:00 Thread-23 After CLEANUP, res=-1ENG: 2007-09-24 13:06:41 BST GMT+01:00 Thread-23 exiting cleanupENG: 2007-09-24 13:06:41 BST GMT+01:00 Thread-23 entering task-failedTo our knowledge nothing has changed other than the upgrade of the Teamsite software. Anybody with some ideas on what we can try?Many thanks,Alyssa
We've tried adding in the TS version line to the deploy.cfg files on the OD recievers and restarted them but this hasn't helped either.
Deploys are working to our development site but not to our live site. We've tried adding in the TS version line to the deploy.cfg files on the OD recievers and restarted them but this hasn't helped either.
From the same server, deployments work to one set of receivers but not to another set ? What is the OD receiver level for each side ?
That's correct, the deploys from the same server work to one reciever but not another. The recievers that deploys are failing for are on webservers that are behind a firewall. We have checked connectivity through the Firewalls and it looks fine, and the receivers are showing that they are receiving some of the jobs from the base server.
I vaguely recall a post indicating that you must not be too precise with your TS Version, OD does not recognize these *details*.Try "teamsite.version: 6.7.0" first ( 3 digits, basic Version ) and "teamsite.version: 6.7.1" if that does not work. Do not forget to restart Service.I *think* that you do not need this setting on the receivers
This worked out great for meTY ISCBoris
