externaltasks not running / impersonation issues?
Adam Stoller
Environment
ideas?
Adam Stoller
I believe I found the answer in
Support KB # 60319
the information
is
in the manual - just not in the same place as the discussion on iwutild / iwutild.cfg.
Basically - there's a different setting to use in iw.cfg:
[authentcation]
disable_ext_task_impersonation=true
I'm not sure if I still need the
impersonate_without_password
setting, but I'll play with that later.
