Issue while removing string from path browse using visual formater editor
sniv
My directory structure on TS is as follows -
Intranet_wa
html
>> images >>abc.pdf
I have DCT with text field (Visual format editor ) which contains the content body. Content body may have some link which points to documents (pdf,doc,images etc.)
When I browse the pdf file using the hyperlink from Visual format editor, then link path start with - /html/images/abc.pdf . Which is correct as per branching structure.
But I need to remove the "/html" from path.
So how I can remove same, as it is part of content body.
Thanks in advance.
There are no comments yet
