When I am trying to build tool kit for customizing online help I am getting following error. The platform I am using is windowsC:\Documents and Settings\Administrator>cdC:\Program Files\Interwoven\TeamSite\local\config\lib\content_center\customer_srcThe filename, directory name, or volume label syntax is incorrect.C:\Documents and Settings\Administrator>cd C:\Program Files\Interwoven\TeamSite\local\config\lib\content_center\customer_srcC:\Program Files\Interwoven\TeamSite\local\config\lib\content_center\customer_src>C:\Progra~1\Interw~1\TeamSite\iw-perl\bin\iwperl C:\Progra~1\Interw~1\TeamSite\bin\make_toolkit.iplJAVA_HOME=C:\PROGRA~1\INTERW~1\TeamSite\tools\javaBuildfile: C:\PROGRA~1\INTERW~1\TeamSite\local\config\lib\content_center\reference\build.xmlinit:compile:validate:[xmlvalidate] 8 file(s) have been successfully validated.[xmlvalidate] 8 file(s) have been successfully validated.files: [delete] Deleting: C:\Program Files\Interwoven\TeamSite\local\config\lib\content_center\customer_out\customer.tk.war [war] Building war: C:\Program Files\Interwoven\TeamSite\local\config\lib\content_center\customer_out\customer.tk.warBUILD FAILEDC:\PROGRA~1\INTERW~1\TeamSite\local\config\lib\content_center\reference\build.xml:119: Execute failed: java.io.IOException: CreateProcess: C:\PROGRA~1\INTERW~1\TeamSite\iw-perl\bin\iwperl C:\PROGRA~1\INTERW~1\TeamSite/install/clean_tk_war.ipl ../customer_out/customer.tk.war error=193Can any one suggest any possible reason for this Thanks in advance
