Here it is, I dont know how will you figure out problem from this one trueWorkflow Properties2true$IW_USER63.0StartEvent54.649414falsefalseTaskUserTask$IW_USERItsUserTask55.75$IW_WORKAREA203.00falsenonetruefalsefalseTaskUserTask2AIM-INT1\jigneshItsUserTask52.75$IW_WORKAREA407.00falsenonetrueEndEvent219.64941409.0Flow5DefaultFlow6DefaultFlow7DefaultFlow8Default
Here it is, I dont know how will you figure out problem from this one [html] true Workflow Properties 2 true $IW_USER 63.0 Start Event 54.649414 false false Task UserTask $IW_USER ItsUserTask 55.75 $IW_WORKAREA 203.0 0 false none true false false Task UserTask2 AIM-INT1\jignesh ItsUserTask 52.75 $IW_WORKAREA 407.0 0 false none true End Event 219.64941 409.0 Flow5 Default Flow6 Default Flow7 Default Flow8 Default[/html]
Here's a more visible, more nicely formatted version of the post.
I created a simple workflow start ---- user task1 ---- user task2---- endI used workflow modeler to create this workflow and created it offline.I modified attributes owner as kkk-int1\anup for user task1 and kkk-int1\kalpana for user task 2 in properties.I saved this file as trialWorkflow.ipm and imported them in the iwadmin in teamsite in trialWorkflow_config folder(as default_config) and submitted it using submit workflow. I imported trialWorkflow.ipm in the models folder and submitted it using submit workflow.I configured manage workflow file under Administration tabNow when I am trying to instantiate a job using this workflow with submit button, it is not working.What did I do wrong ? Can anyone pls explain ?
