Hi;
VCM 7.6
I have a problem when I trying to start a VCM server.
It throws the next trace, and AdminServer not start:
####<31-ago-2010 15H15' CEST> <Error> <EmbeddedLDAP> <ieci-micinn-mgmt> <VgnAdminServer> <[STANDBY] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1283260533372> <BEA-000000> <Error Instantiating 'dc=vgndomain': null>
####<31-ago-2010 15H15' CEST> <Critical> <EmbeddedLDAP> <ieci-micinn-mgmt> <VgnAdminServer> <[STANDBY] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1283260533383> <BEA-171522> <An error occurred while initializing the Embedded LDAP Server. The exception thrown is java.lang.ClassCastException: com.octetstring.vde.backend.BackendRoot. This may indicate a problem with the data files for the Embedded LDAP Server. If the problem is with the data files and it can not be corrected, backups of previous versions of the data files exist in /mnt/hdb/opt/Vignette/Content/7_6/rtsvcs/domains/vgndomain/servers/VgnAdminServer/data/ldap/backup.>
####<31-ago-2010 15H15' CEST> <Critical> <WebLogicServer> <ieci-micinn-mgmt> <VgnAdminServer> <Main Thread> <<WLS Kernel>> <> <> <1283260533390> <BEA-000362> <Server failed. Reason:
There are 1 nested errors:
at weblogic.ldap.EmbeddedLDAP.start(EmbeddedLDAP.java:273)
at weblogic.t3.srvr.SubsystemRequest.run(SubsystemRequest.java:64)
at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java:464)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:200)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:172)
Can anyone helpme?
Thank you
