HI All,
I was migrating my application to our new environment just to perform tests with VAP 8.1 I managed to configure my application server which is JBOSS 5.0.0 to run properly VAP and also to properly import the portelts however... seems there is a problem when trying to call the portelt VAP fails to render it.
With the below exception:
2010-09-17 18:00:07,364 [ajp-3.126.92.86-8009-4] ERROR org.apache.catalina.core.ContainerBase.[jboss.web].[localhost].[/TestPocPortlet] - com.sun.faces.portlet.ViewHandlerPortletRenderResponseWrapper cannot be cast to com.vignette.portal.portlet.jsrcontainer.internal.standardcontainer.invocation.apiimpl.InternalRenderResponse
java.lang.ClassCastException: com.sun.faces.portlet.ViewHandlerPortletRenderResponseWrapper cannot be cast to com.vignette.portal.portlet.jsrcontainer.internal.standardcontainer.invocation.apiimpl.InternalRenderResponse
at com.vignette.portal.portlet.jsrcontainer.internal.standardcontainer.invocation.apiimpl.PortletRequestDispatcherImpl.include(PortletRequestDispatcherImpl.java:199)
Any of you have faced this issue before? This is just simple portlet that prints you a string.
Please let me know, I think it's only a problem with the way we print the portlet.
Regads,
