Hi Guys,
We have installed TeamSite from the scratch in Solaris Box, by refering exactly the step by step installation document. Presently, the TeamSite is working fine as desired. Except from TeamSite login window by hitting
http:///iw/webdesk/login, if we type in the URL as
http:///iw-cc/base/util, we get the directory index.
We want to disable the directory indexing of the teamsite data store. For that, we searched for the web server configuration in TeamSite and found an iw-webd directory which holds the web configurations under the TeamSite installation directory. We found an httpd.conf too, under iw-webd/conf folder. We want to make sure, by editing the configuration file for .htaccess file will resolve our scenario. Anybody could advice us in this regard?
Thanks in advance,
Leenus.
