Yep,I can run it from the command line (as myself).The server is definitely up.... Lots of other inlines etc working fine.Is there any way to impersonate iwui from the command line maybe?
On solaris you should be able to: su iwui iwlist
When called from the inline all that is set is:[PHP]IW_USER:adcj8pbIW_ROLE:adminIW_DCT: (path blanked)IW_WORKAREA: (path blanked)[/PHP]
BEGIN{ $ENV{'SHELL') = q(/bin/sh); $ENV{'PATH'} = q(/usr/sbin:/usr/bin); ...};
Hmm. Interesting,Why would all of the environment variables suddenly stop getting populated?As mentioned, it was all working well a couple of days ago.
