I need to pick up some database entires and show it on my page. However my project is structured such that page tpl file includes other small module tpl files.. as a result a direct in-line comment to read data from db doesnt work for me.
To sort this out, i am using the TeamSite:
T::iw_sql_open, so that i can use it in my module tpl files and access data on the main page tpl. I am using the following code to acheive this -
beg- iw_sql_open data_source = "dbi
racle:"
user_name = "starcms"
password = "cmsstar"
aux_env = "ORACLE_HOME => '/export/home0/oracle/app/oracle/product/9.2.0',
ORACLE_SID => 'TTDT'">
close - iw_sql_open
(the tags get parsed automatically and hence usage of "beg" and "close")
All the above parameters are correct, i.e. the username, pwd, SID, Oracle home etc. But when i run it, it doesnt give me any results. I have not included anything other than to be able to access the DB?
Is this not sufficient enough? Any other suggestions? I tried debugging using the iwpt_compile.ipl but there is not much useful information there as well
