Hi
I am having trouble with OpenDeploy.
I can publish content from the TeamSite server to the file system as well as the to db of the target web site except for one type of data, serviceDetail.
The logs for everything show success apart for this data type so far.
The logs show:
ENG: 2008-12-30 15:23:11 GMT+00:00 Proceed to execute the database deployment
DBD: Deployment : ServiceDetail
DBD: ERROR
eployment not found
DBD: ERROR:ERROR: Unable to determine operation mode
DBD:
### IWDataDeploy FAILED ###
DBD:
### Sending result ###
ENG: 2008-12-30 15:23:11 GMT+00:00 Database deployment execution returned 1
ENG: 2008-12-30 15:23:11 GMT+00:00 <<< Completed database deployment Invocation>>>
ENG: 2008-12-30 15:23:11 GMT+00:00 Manifest path is C:/Interwoven/OpenDeploy/OpenDeployNG/log/dd-conf/src.eversheds_com.ServiceDetail.UKBIRAP06.to.database.log.mf
ENG: 2008-12-30 15:23:11 GMT+00:00 Got Manifest object com.interwoven.od.adapter.delivery.base.IWODManifest@1527c4a
ENG: 2008-12-30 15:23:11 GMT+00:00 fHasFailedItems is set to true
Looking in the deploy log in directory "C:\Interwoven\TeamSite\tmp" I take the command
C:\Interwoven\TeamSite/iw-perl/bin/iwperl C:/Interwoven/OpenDeploy/OpenDeployNG/solutions/perl/iwodstart.ipl
I run this in a DOS window with all the associated params and get the following:
Locating OpenDeploy service.
Got OpenDeploy service
>>>>>-- Start deployment LiveSite525480.
iwodstart running in default synchronous mode.
Need to wait for deployment to complete.
>>>>>-- Deployment LiveSite525480 finished:
ID: m21 Start time: Tue Dec 30 15:23:11 GMT 2008
Status: Failed
STATUS: 2
OpenDeploy Failed at C:/Interwoven/OpenDeploy/OpenDeployNG/solutions/perl/iwodstart.ipl line 110.
The final line of the code below is line 110 this is the status being greater than 1.
# ---- CMD TO RUN OD CLIENT COMMAND
my($CLIENT_CMD) = join(" ",
"$ODCMD_EXE",
"$OD_CMD",
@MYARGS);
#print "CLIENT_CMD: '$CLIENT_CMD'\n";
# ---- RUN OD CLIENT COMMAND
open(PIPE, "$CLIENT_CMD 2>&1 |");
while(){
print $_;
close(PIPE);
#`$CLIENT_CMD`;
my($status) = $?;
if ($nostatus == 1) {
$status = 254;
} else {
$status >>= 8;
print "STATUS: $status\n";
warn "OpenDeploy Failed" if ($status > 0);
Any advice/assistance is much appreciated.
Thanks
T
