Thanks for the response Chris, I actually tried using an external task it was perl IPL got the external task to set the task description but it shows as a task comment but not as the task description. I had some default task description for the review task on WFM, and that is what showed up. I removed the task descrption from WFM and left it empty but that didnt help either. anyother suggestions?.
