Help required on using Spry technology with TPL
Smita
I have to develop a TPL (presentation template) using Spry framework, in which I have to read data from an XMLDataSource.
I am using the following Spry code to read from an xml file:
var getFormParameters = new Spry.Data.XMLDataSet("customComfortsForm_formParameters.xml", "emailValues");
where customComfortsForm_formParameters.xml is name of xml file(attached with message) Now when I am using
var formParams = getFormParameters.getData();
its returning null value. I tried giving both absolute and relative path for the xml file but it’s not working. I am always getting formParams as null.
This same Spry code is working fine in a html file.
Please suggest. Any pointers in this regard will be of great help.
vy8359
I am not sure what you are trying to do
but per adobe here is the syntax.
http://yoursite/somefolder/somefile.xml
", "category/menu");
Try the xml file url in seprate browser first.
Note: Remember that JavaScript and XML are case-sensitive languages, so it's important that you make sure that the scripts and column names you specify are capitalized (or not capitalized) appropriately.
